Re: Ever use a Comp Cams XE268H in a BB?
[Re: Boise Chall]
#869829
12/03/10 01:56 AM
12/03/10 01:56 AM
Posts: 1,630 North Central Florida
eightlitermopar
My brother had one in a loaner motor I gave him. Low compression 78 440. Headers, hot ignition, and 2800 rated stall converter, 3.91 rear in a 69 Bbody.
It was fun to drive and pulled hard, but the compression was low and the rings were crap (oil started to have a gas smell)
Anyway, best run was shocking at 14.5 seconds in the quarter. It definately felt like it pulled harder than that...but....for a street car, its a good choice.
He was offended at the 14.5 timeslip, so he got a 493 eddy headed stroker! eight
Mopar or no car
[Re: eightlitermopar]
#869830
12/03/10 12:33 PM
12/03/10 12:33 PM
Posts: 383 Essex, Ont., Canada
Fishmarket
Essex, Ont., Canada
I've got one in a 383 stroked to 432. Stock heads, home ported with 2.14/1.81 valves, holley street dominator intake and a holley 750, 9.2 to 1 compression. Engine made 430 horsepower and 470 foot pounds of torque on a DTS dyno. If i did it again i would go with the XE275HL or preferrably a hydraulic roller.
1972 Plymouth Cuda 340 4 speed
1971 Plymouth Road Runner 383 Auto
1970 Plymouth Duster /6 Auto
[Re: Fishmarket]
#869831
12/03/10 02:00 PM
12/03/10 02:00 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Two of them in customer's cars. They run very well.
[Re: moper]
#869832
12/03/10 09:48 PM
12/03/10 09:48 PM
Posts: 565 IA
landon1
IA
have one in my 440 - i love it, but all i have to compare it to was the 35+ year old stock motor
'71 Satellite Sebring 440
[Re: Kern Dog]
#869834
12/03/10 11:59 PM
12/03/10 11:59 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I'd think it'd be the cats' meow for a stockish/mild street 383....personally, it seems like most chrysler guys overcam their motors.
[Re: patrick]
#869835
12/04/10 12:17 AM
12/04/10 12:17 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
It's possible or just don't have a clue what a real cam is.
[Re: goldmember]
#869838
12/06/10 12:09 PM
12/06/10 12:09 PM
patrick
Grand Haven, MI
maybe I like to "speak softly and carry a big stick", with a decent idle and low speed manners but still able go fast vs. sounding like a super stocker but not being able to get out of it's own way
if you have good flowing heads, and a well thought out package, you don't need to have a big cam to make big power. look at the LS7 in the ZO6--505HP out of a cam that IIRC is ~218@.050, or the 5.7L hemi, IIRC comp got 460HP out of one with either a 218 or 224@.050 hyd. roller....or a number of 318 dak guys who are well into the 13's with hyd. rollers in the 212-218@.050...
[Re: patrick]
#869839
12/06/10 12:21 PM
12/06/10 12:21 PM
goldmember
Gainesville,FL
if you have good flowing heads, and a well thought out package, you don't need to have a big cam to make big power. look at the LS7 in the ZO6--505HP out of a cam that IIRC is ~218@.050, or the 5.7L hemi, IIRC comp got 460HP out of one with either a 218 or [Email]224@.050[/Email] hyd. roller....or a number of 318 dak guys who are well into the 13's with hyd. rollers in the [Email]212-218@.050...[/Email]
I don't want to trash the OP's post so I'll leave you to fantasy land.
[Re: V194]
#869840
12/06/10 03:25 PM
12/06/10 03:25 PM
Posts: 2,677 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have one in a .030" over 383.It's around 9-1 probably less. Pistons were rated at 9.2-1 and dished.I don't know the deck height. Using 906 heads, stock converter, and 3.23 gear. This is a nice cam. Enough thump to say it's not stock. Very drivable without idle problems in gear. I had the 474/280* purple shaft in this engine before and pulled it when the lobes went flat. This cam has much better vacuum, drive-ability, and performance in this application. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: goldmember]
#869841
12/06/10 09:19 PM
12/06/10 09:19 PM
Posts: 1,200 UK
602heavy
UK
Don't know about 'fantasy land' some truth in Patricks post........motor will most likely be DOWN on power using that 268/280 split , 268/268 should get the job done. ![](/ubbthreads/images/graemlins/biggrin.gif)
Lopey idle is due to int/ex split , much better manners to be had going single pattern.
[Re: 602heavy]
#869842
12/07/10 02:04 AM
12/07/10 02:04 AM
Hemi Allstate
Mt. Eden Ky.
Don't know about 'fantasy land' some truth in Patricks post........motor will most likely be DOWN on power using that 268/280 split , 268/268 should get the job done. ![](/ubbthreads/images/graemlins/biggrin.gif) Lopey idle is due to int/ex split , much better manners to be had going single pattern.
I guess you know that this cam is 224* and 230* @ .050" . It compares favorably to all others in the Comp Cams Cam Quest program, for this application. Including those with single pattern. The split pattern is a good choice for use with exhaust manifolds according to the Comp Cams tech. Which is what my application is. Also, isn't it a fairly common practice to aid the exhaust side flow, and to try and achieve near 75% of the intake flow, by increasing the lift and or duration on that side?![](/ubbthreads/images/graemlins/shruggy.gif) Mark
[Re: 602heavy]
#869844
12/07/10 03:07 AM
12/07/10 03:07 AM
goldmember
Gainesville,FL
Choosing a cam that would be lucky to make 1hp per cube and trying to find a link to what you can do with a late model hemi or LS is fantasy land. Either engine can be upgraded easily in the cam dept if big output is the name of the game,but you may have a little loss of idle vac,big deal IMO. I guess when you've swapped and tested cams in a vehicle and not on desktop dyno or a magazine add you see things from a different perspective. To the OP sorry to see your post pop off track. To the point, I have never ran that cam but have known others that tried it,never seen an over achiever in the bunch(obviously lots of pieces to any combo),but I'll keep my eyes open. I think in the future I'll shut up and just say you'll love it and go about my business.LOL Lot's of good tech has vanished from Moparts and other sites,wonder why?
