Well. lets try to attach some real numbers to the question, with a few assumptions thrown in.
Say A TF produces 6,000hp.
Assume 33% efficiency, 1/3 hp/work, 1/3 Heat, and 1/3 acoustic energy.
1 Hp equals 754? acoustic watts.
A Very high grade Pro Sound system might approach 30% output efficiency, means you put in 100 Watts RMs, you only get 30 acoustic wattss output.
A high end home stereo might aprroach 10%, typically they are 1-4%.
Therefore your home stereo would need RMS watts to reproduce a TF:
6000(HP)x 754 / .04= 113,100,000 Watts
Your neighbors would likely complain
![](/ubbthreads/images/graemlins/grin.gif)
