Re: how to pull an alternator pulley? [Re: Snoopy] #866917
11/30/10 09:27 PM
11/30/10 09:27 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Original Miller tool.
Re: how to pull an alternator pulley? [Re: 62maxwgn] #866918
11/30/10 10:34 PM
11/30/10 10:34 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
To install I use a 100 watt light bulb. Just put the new pulley directly on the lit bulb for 15-20 minuets. This should evenly heat it up so that the hole is large enough to slide on to the shaft of the alternator. On larger things that need a shrink fit I use a oven to get it expanded. There should be about .002" interference between the shaft and the pulley if not it will slip on the shaft. Not all alternators have the same shaft/pulley size.
Re: how to pull an alternator pulley? [Re: convx4] #866919
11/30/10 11:43 PM
11/30/10 11:43 PM
scratchnfotraction Offline
i see the light,thats a good idea
like putting the screw/press in upper/lower ball joints on my 85 truck,stick them in the freezer overnight to shrink them some
Re: how to pull an alternator pulley? [Re: convx4] #866920
12/01/10 01:23 AM
12/01/10 01:23 AM
Heck of a tip. I'll have to try that. I wouldn't think a 100W bulb would be enough heat.
Re: how to pull an alternator pulley? [Re: RapidRobert] #866921
12/01/10 01:27 AM
12/01/10 01:27 AM
ever been burned by a ruff service 100 watt bulb in a hand held shop light with metal shroud thats been on for hrs?
i wont grab it like that no more either
bet it would work on a crank damper also
Re: how to pull an alternator pulley? [Re: 62maxwgn] #866922
12/01/10 03:03 AM
12/01/10 03:03 AM
Toronto, Canada
dirtybee Offline OP
dirtybee  Offline OP
Toronto, Canada
that's the exact tool i used. heat seems like a great idea.
Re: how to pull an alternator pulley? [Re: dirtybee] #866923
12/01/10 09:14 AM
12/01/10 09:14 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Problem with the Miller tool is finding one.The kit is a loaner from Advanced Auto Zone.How many pulleys will you change at home.Now if you can find the Miller cheap thats a different story.Rocky
Chrysler Firepower
Re: how to pull an alternator pulley? [Re: convx4] #866924
12/01/10 10:19 AM
12/01/10 10:19 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Dry Ice on the shaft to shrink it helps too,
along with gentle heat like a light bulb on the pulley.
Many grocery store chains sell Dry Ice and it is cheap, typically $7 per pound at Publix stores in Florida, for example.
If you can't find Dry Ice
these 'Freeze It' sprays are helpful too
http://www.crcindustries.com/ei/content/pst.aspx?PID=Panel2_3
http://www.amazon.com/CRC-05222-Freeze-Off-Super-Penetrant/dp/B000KKCQUW
http://www.loctitefreezeandrelease.com/instructions.htm
Re: how to pull an alternator pulley? [Re: scratchnfotraction] #866925
12/01/10 11:59 PM
12/01/10 11:59 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
All the time and it hurts. Makes me want to get a light with a plastic housing.
Re: how to pull an alternator pulley? [Re: 69Cuda340S] #866926
02/20/11 10:19 PM
02/20/11 10:19 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I'm using the exact tool (in red box) shown above. I'm reefing on this thing pretty hard, and it isn't budging.... How hard should it be?
