Re: Stock and Super Stock guys who did your head work!?
[Re: ChrisJohnston669]
#866879
11/30/10 12:30 AM
11/30/10 12:30 AM
Posts: 2,946 Windsor ,Ca.
Keith Richards
Windsor ,Ca.
lol by local I meant this coast. A Cali guy. I also heard that Wes King does top end work.
I would call Angie at Mopar Engines West, although Wes did some magic on a pair of Eddy's for me years back. The work that Angie did on the Engine Challenge motor (which I now own) is second to none.
#866881
11/30/10 01:21 PM
11/30/10 01:21 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
IMO hard to argue with the Wann's success at this stuff.
Also IMO it depends on your goals. Are you looking to be able to qualify well or are you wanting record setting stuff. That will make a big price difference.
There is also RWR, and as mentioned Pettis. Or you can buy Studley's old record setting Dakota it is for sale.
You buildiing it I assume as a traditional SS car not a GT?
[Re: moderncylinder]
#866885
11/30/10 05:44 PM
11/30/10 05:44 PM
Posts: 977 Poulsbo, WA
ChrisJohnston669
Poulsbo, WA
what kind of magnum? a stock iron head? rt head? or alum ed/mopar head?
After talking to a friend I'm thinking maybe some cast iron W2s and a 340. Should put me in GT/TC. I like the idea of no tear downs.
#866886
11/30/10 06:06 PM
11/30/10 06:06 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
with that combination, no port rules, valve size rules,, or anything,, not saying that he couldnt get around all that,, id try brian, ou812 on here.. he seems to be a small block guy but a cylinder head guy overall,,, he might take a special interest and treat you good on the labor
#866890
11/30/10 09:38 PM
11/30/10 09:38 PM
Posts: 11,683 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
10.5 lb/cubic inch, 3000# minimum, cast iron heads only. 286 cu.in. at minimum weight. A 340 would have to weigh 3570 with driver less 250 with an automatic. 10.50 index. No one currently holds the record. Sounds like fun.
Same combination in a car is a 10.30 index and a Mopar from the mid-west holds the record with a 9.25.
#866892
12/01/10 02:07 PM
12/01/10 02:07 PM
Al_Alguire
Las Vegas
I believe that is what Curtis Boggs runs in his Daytona in SS/CS or BS. Does sound like fun, not that many trucks out there in SS, I have seen mainly GT trucks. I forgot about Brian at IMM. I know I plan to take him some stuff later next year once life is a bit more settled.
[Re: Al_Alguire]
#866893
12/01/10 02:30 PM
12/01/10 02:30 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Sounds like fun! I would need a copy of all the rules but I can make time for that you bet. Thanks guys.... Brian
Brian Hafliger
