Speedo cable - where does it run
#866412
11/29/10 01:42 PM
11/29/10 01:42 PM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
After refreshing the entire dash with all the stuff attached to the firewall there is one thing left, that I cannot remember how it was before disassembling:
Where does the speedometer cable run through?
I'm talking about a 1970 Challenger 440 with 4 speed MT.
The most questionable part is from the firewall to the speedometer - how does it pass the pedals? Does it run between brake and clutch pedal? On what wide of the clutch pressure rod? Where is it fixed there - is it fixed at all??
Also in the engine bay I'm not sure. Does it run between brake valve (and all the brake lines) and fender on the left side? Or goes it between the brake lines? Or on the right side of the brake stuff?
It passes the Z-bar right on the outside/ left side where the frame is, right? There is a clip to fix it to the frame - is that clip exactly under the Z-bar?
Hmm - let me extend this: Where does the (double) wire run to the transmission backup light switch? Along with the speedo-cable??
I add a pic just for fun - it does not show the questionable cable. Just to show that I found where to put the rest of things...
After all these years having a 440 I realized that this means having an attitude... and a budget.
Re: Speedo cable - where does it run
[Re: Swiss_Robert]
#866413
11/29/10 10:12 PM
11/29/10 10:12 PM
Posts: 2,059 NW/Indiana - Chi town
ricomondo
Not sure if it's correct, but Ive always run it thru the steering column support bracket (if thats whats its called) it has the upright rectangular opening, and I put the speedo cable right thru the center. Sorry I dont have a pic. Maybe someone else does.
GY3 71 Demon 340
[Re: FJ5_Fish]
#866415
11/30/10 05:15 AM
11/30/10 05:15 AM
Swiss_Robert
Switzerland, Europe
Placing it on that "bent edge" on the left side of the column support would make sense... But then one must fix it there or it will sooner or later be smashed by the clutch pedal stop-cam. So was there some kind of clip when it was stock? Else one must drill a hole to fix it with a cable tie. And to guide it there - will it pass the clutch pushrod on the left side... or shall I say "under" or "in front of" that pushrod? @ricomondo: Sure that's for a rally dash? The speedo is on the left side of the column support... I'll take a look again but can't really visualize. I've had it already in at least three different positions - and everytime it looked just odd... ![](/ubbthreads/images/graemlins/confused.gif) ...while lying on the back in the empty car for LONG, shaking head under the dash in disbelief, having just no more ideas... ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Swiss_Robert]
#866416
11/30/10 11:09 AM
11/30/10 11:09 AM
Posts: 2,316 South, FL
cudaized
South, FL
...I cannot remember how it was before disassembling: Where does the speedometer cable run through? The most questionable part is from the firewall to the speedometer - how does it pass the pedals? Does it run between brake and clutch pedal? On what wide of the clutch pressure rod? Where is it fixed there - is it fixed at all??
Sie sind herzlich willkommen
Perhaps these 5 pictures will help you? With this routing of the cable, the clutch pedal does not have any interference. Ola
Cable 1
[Re: cudaized]
#866421
11/30/10 11:39 AM
11/30/10 11:39 AM
Swiss_Robert
Switzerland, Europe
Ahhhhhhhhhhhhhhhhhhhh! ![](/ubbthreads/images/graemlins/beer.gif) That's a good one! Looks very great... I'm gonna try that and I think that's the way to go. Funny - I've never got the idea to guide it OVER the clutch pedal. THANKS!
[Re: FJ5_Fish]
#866425
11/30/10 07:15 PM
11/30/10 07:15 PM
Swiss_Robert
Switzerland, Europe
Great, thanks!
Hmmm - where will you route the backup-light cable?
[Re: FJ5_Fish]
#866427
12/01/10 12:37 PM
12/01/10 12:37 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I know this post is about a 1970 but for those who have 72-74 cars and are wondering how the cable is attched to the floorpan...
The newer cars don't have a clip welded to the floor. They use a white plastic strap... the same strap that's used on the DS inner fender to hold wiring. I assumed that the strap clips into a hole in the small frame to floorpan bracket. In the above pics, there is a brake line clip in that hole. I don't know if the newer cars used a brake line clip at that point or not. That is the only place I can see to mount the strap.
[Re: Swiss_Robert]
#866428
12/03/10 01:40 AM
12/03/10 01:40 AM
cudaized
South, FL
Some more pictures...
