Re: Speedo cable - where does it run
[Re: cudaized]
#866432
12/03/10 05:12 AM
12/03/10 05:12 AM
Posts: 263 Switzerland, Europe
Swiss_Robert
Switzerland, Europe
Great, thank you!
No idea who sells that clip.
It's the first time, I see how this linkage looks - the one that locks the ignition key over the "shifting tube" when there is a manual transmission. I assume that thing is often absent - as it is in my car...
After all these years having a 440 I realized that this means having an attitude... and a budget.
[Re: Swiss_Robert]
#866434
12/03/10 10:17 AM
12/03/10 10:17 AM
Posts: 2,316 South, FL
cudaized
South, FL
You are indeed correct. A lot are missing. Who wants to put the car in reverse, just to get the key out. A pain in the @ss if you ask me. Especially if your A833 is a little worn out and is hard to get in reverse. Or those straight cut gears are not lined up exactly.
There are originals for sale (usually not complete) and also reproductions.
[Re: moparo]
#866438
12/03/10 10:52 PM
12/03/10 10:52 PM
Posts: 1,294 Ontario, Canada
FJ5_Fish
Ontario, Canada
I have those clips
I also have seen the same whitish looms which hold the wiper hose to the fire wall on the passenger side on an e-body.
When you say you have those clips - do have them on an E-Body or you have them in your pocket trying to use them at Tim Horton's? Yes - A couple of mine have the white straps too.
Here is where it broke off....
[Re: FJ5_Fish]
#866440
12/03/10 11:39 PM
12/03/10 11:39 PM
Posts: 21,537 It's a dry heat
gtx6970
It's a dry heat
Wow - Never seen those frame rail clips on E-Bodies - Only B-Bodies. I don't believe any of my cars have ever had them. Time for a closer look.
Jim. My old 70 challenger 340 had one and the current 70 cuda I'm working on now has one
[Re: FJ5_Fish]
#866443
12/04/10 12:07 AM
12/04/10 12:07 AM
Posts: 1,105 Ont, Canada
moparo
Ont, Canada
I think it might be a plant thing.
performancecarrestorations.com
[Re: FJ5_Fish]
#866444
12/04/10 12:10 AM
12/04/10 12:10 AM
moparo
Ont, Canada
The picture of the car with clip is a convert.
Check your ebody convert Jim
[Re: cudaized]
#866447
12/04/10 02:58 PM
12/04/10 02:58 PM
moparo
Ont, Canada
Well that shoots that out the window.
