Re: RB fuel injection questions
[Re: rice2muscle]
#864863
12/03/10 07:48 PM
12/03/10 07:48 PM
DaytonaTurbo
Manitoba, Canada
so for you guys running megasquirt, are you running the fuel only? or are u running it with a distributor mod so ur timing is through the ecu too?
I'm setting mine up to do both but you can go either way.
[Re: rice2muscle]
#864864
12/03/10 08:31 PM
12/03/10 08:31 PM
Posts: 965 Odessa, Fl
blowndart
Odessa, Fl
blown dart, are u running megasquirt?
Yes. MS2
[Re: rice2muscle]
#864866
12/04/10 08:38 AM
12/04/10 08:38 AM
blowndart
Odessa, Fl
fo the rb mope, is the only way to control the timing by adding a crank trigger???
No. I'm using my distributor. You need a distributor that has no advance function. You can lock out the advance on an MSD or use a lean-burn factor distributors which have no advance function, for example.
[Re: Dragula]
#864867
12/04/10 12:43 PM
12/04/10 12:43 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
The self learning update on the new XFI, I didn't realize it has an HP limit.
That's an error! The EZ system has a HP limit because of it's requirement to run only high-Z injectors, and with a single TB you have only 4 injectors. You can go to about 850 HP with the port injected EZ system (8 injectors) but you are still limited by the flow rate of high-Z injectors.
The new XFI 2.0 has NO horsepower limit!
[Re: Mopar_Rich]
#864868
12/05/10 06:56 PM
12/05/10 06:56 PM
Posts: 200 AB
Efidart
AB
Ran my MS II well into the 8's and drove lots of street miles with it. Worked well but got tired of waitng for the LCD Dash firmware upgrades and the MS 3.. So I bought a BS3 and Racepak dash which works great but will be going back to an MS3 soon enough.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
