runability problem 93 caravan #86374
07/09/08 03:03 PM
07/09/08 03:03 PM
new berlin wisconsin
Mr T2U Offline OP
Mr T2U  Offline OP
i have a 93 caravan 2.5L 5 speed manual 190,000 on body 40,000 on rebuilt crate motor. someone else did the motor replacement so i don't know what parts they switched over between motors.
when putting a light load on the engine i have a intermittent miss.
biggest problem. when on the freeway at proper speed everything is fine. when i hit a hill i have a intermittent miss. i can down shift to 4th gear and it will clime the hill no problem.
SOMETIMES i also have a problem starting out from a dead stop not to often. i can start accelerating and it will fall on it's face. if i press the gas down the problem gets worse. if i leave the accelerator alone and drive a few feet it will clear out and run fine. or i push the clutch in, rev the motor, then dump the clutch it will chirp the tires and go.
when there isn't any load on the motor it revs fine without any miss.
i replaced the coil, plugs, wires, cap and rotor. and checked all of the grounds, they all test out fine. i was told check the EGR valve but it doesn't have one.
ideas to repair? distributor? computer? fuel filter?
i just bought a replacement for this car so i would like a cheap repair. or better yet sell it with this problem and tell buyer what should fix it.
thanks in advance moparts family
perception is 90% of reality
Re: runability problem 93 caravan [Re: Mr T2U] #86375
07/10/08 08:21 AM
07/10/08 08:21 AM
Mr T2U Offline OP
Mr T2U  Offline OP
Re: runability problem 93 caravan [Re: Mr T2U] #86376
07/10/08 08:27 AM
07/10/08 08:27 AM
try some injector cleaner.
Re: runability problem 93 caravan #86377
07/10/08 08:54 AM
07/10/08 08:54 AM
Mr T2U Offline OP
Mr T2U  Offline OP
i did. i used 2 bottles of STP fuel system cleaner in the tank, now it seems to idle rough. i also put some 93 octane in the tank to. i figured a little extra octane couldn't hurt anything.
Re: runability problem 93 caravan [Re: Mr T2U] #86378
07/10/08 10:32 AM
07/10/08 10:32 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you checked for fault codes?
Re: runability problem 93 caravan [Re: stumpy] #86379
07/10/08 11:42 AM
07/10/08 11:42 AM
Mr T2U Offline OP
Mr T2U  Offline OP
no i haven'r scanned it yet. the check engine light isn't on. i figured with that old of a car there wouldn't be any
Re: runability problem 93 caravan [Re: Mr T2U] #86380
07/10/08 12:47 PM
07/10/08 12:47 PM
Hummelstown, PA
AINTNRT Offline
AINTNRT  Offline
Hummelstown, PA
Possible O2 sensor. My 89 Daytona with 2.5 and 5 spd acted similar. Code was set for O2 stuck center but no CEL.
