Re: 440 or 451 stroker? [Re: JohnRR] #863545
11/29/10 06:53 PM
11/29/10 06:53 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Don't notch the bottom of the bore unless you are using LEAD pistons, otherwise you'll end up with swiss cheese looking counterweights to balance it for the stroker , after cutting mine it only needed a couple small shallow holes to balance .
John,
What pistons did you end up using?
Re: 440 or 451 stroker? [Re: CompSyn] #863546
11/29/10 09:26 PM
11/29/10 09:26 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
John,
I used diamond pistons with a 1.320 CH , they were under 600 grams , I want to say 650ish with the pin
