Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: B1CUDA] #863236
11/26/10 01:11 PM
11/26/10 01:11 PM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
Bob, In a nutshell, you need to do the exact opposite of your first sentence in your post. To get the full potential out of one of these Hemi's, at this weight, you absolutely have to rely on the 7531, and find the sweet spot, as far as building instant wheel speed, and managing a constant graph going downtrack, with the most minimal slippage on your gear change. In the N/A world, the 3rd gear is almost considered a "Power adder" as you are going downtrack. I have a Rossler TH210 with all of the lightest internals that Rossler currently offers, and I couldn't be happier. My 8" ATI converter flashes at 8500, and my shift points are set at 9400 (which is an insane feeling when you are skating around on a true 10.5 tire)
My current rear gear is a 5.38, and the converter, according to the Racepak, is only slipping 4%, so, it is in the ballpark.
Here is the info off of the last pass that I made with the car in June, in 5500 feet of air. Outside temp was 96 degrees, Track temp was 122 degrees, in Vegas. (This was only the 3rd pass ever, on this combo)
60 foot: 1.300
1/8th mile: 5.33
1/4 mile: 8.56
MPH: 158.96
Although this doesn't look impressive, I was pumped due to the following reasons.....
We took 15 degrees of timing out for 1.5 seconds, and it still went 1.30 flat 60 foot.
The car literally spins ALLLLL the way through 1st, 2nd & 3rd gear, I mean to the point of hazing the tire all the way down the track. On this pass, I pedaled it twice, as I thought I was going to stuff it into the wall, and the Racepak showed that I was out of the throttle for a total of .38 seconds.
I gathered the car just passed the 1/8th mile cone, and laid into until the 1000 foot cone, where it got very loose again. I let out completely and pulled the chute. Game over.
This car is nowhere, and I mean NOWHERE near it's potential, as we clearly know that we have the car set-up as a POOCH at the hit, and we have only set the shift light to 9400 on the 1-2 & 2-3 one time. (On the pass above)
We have our work cut out for us, in finding that sweet spot, but, I couldn't imagine trying to work with this motor, using a glide. As far as the torque comment, I only know this by the motors that I have owned, but, my old B1-MC motor that now belongs to Al Alguire, made way more torque than this Hemi, which I see as a huge benefit, on this little tire. The problem, however, is the add'l. 350+ HP that this Hemi makes, over my old B1-MC.
I do not know, as I have no knowledge of anyone else in the country with a car set up like mine, but, I would be willing to give the glide a try, if my car weighed 2600-2800 lbs, but, that is not the case. I feel like the 3 speed is a must at this weight.
Here are, what I believe, have been my most valuable assets so far, with this motor...
The 7531 - (Can't wait to give it all of the timing much quicker)
Racepak V-300SD - Hands down IN-Valuable!
I am sure that when all is said and done, before this car meets it's potential, I will probably go through a few converters, and a few gear changes, but, there is no way that I will get rid of the 3 speed. I never, in a million years, thought that this motor would be as "Finnicky" as it is. I was told by Bob Panella that these Pro Stockers are like a high maintenance woman, and it is sooooooo true. (But, still worth it, as it is the most bad-a$$ Mopar engine on the planet)
Happy Thanksgiving!
Absolutely amazing!
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: silverfish] #863237
11/26/10 01:32 PM
11/26/10 01:32 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have no Hight Tech advise,but some Real World advise that might help that I tell all my friends before then switch to a glide. I wish I had knew this myself a few years back before I spend a lot of $$$ for a glide.
Start off in 2nd gear.That will give you a good idea of how your car and engine combo will work with a glide.
This may not be a fair way to compare a T/F to a glide but at least you have a little something else to help you deceide.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobsProFab] #863238
11/26/10 01:46 PM
11/26/10 01:46 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Is a Liberty, Linco or Bruno out of the question?
(rule restricted?)
I know I saw quite a few of them available for about the same cost as a good PG.
Weren't the cars these Hemi 99's came out of 5speeds?
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: DakFink] #863239
11/26/10 04:23 PM
11/26/10 04:23 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'd put a ProStock Liberty 5 speed in the car...
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: JERICOGTX] #863240
11/26/10 04:25 PM
11/26/10 04:25 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
not only would it be fast it would sound BA
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: JERICOGTX] #863241
11/26/10 04:38 PM
11/26/10 04:38 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
Don't know about Bob's rules, but they are not legal in my class. Let me tell ya, if they were legal, I would have one in my car as fast as I could buy it, and put it in.
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: B1CUDA] #863242
11/26/10 06:02 PM
11/26/10 06:02 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
i can run a liberty with no weight penalty as long as it has a clutch
add 50 lbs. to base weight for clutchless
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: B1CUDA] #863243
11/26/10 06:07 PM
11/26/10 06:07 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I totally agree there...a stick and a pro stock hemi go together like bread and butter..
I wouldn't think a glide would work with that combo,as well as a 3-speed..because of the short stroke and weight..and you can run a liberty at Milan with a weight penalty..face it Bob,to run with those boys you have to have a blank check..you need to have as big as cube motor as you can get that short stroke is not going to fly,but it all depends on wnat et you want to run..but anymore at Milan all motor...dont show up unless it will run 8.50's...in 90 degree weather..
Alans chevelle is a bad boy,skinny kid chassis,and a motor that makes 1400 hp with cast manifold single 4 that is set up conservative...
I was thinking about buying Lance Bennets silver mustang and dropping my motor in it liberty and all..that car flys and can get real light..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: FASTFISH420] #863244
11/26/10 06:16 PM
11/26/10 06:16 PM
sycamore,ohio
sycamore,ohio
wish it were weight to C.I.
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobsProFab] #863245
11/26/10 06:28 PM
11/26/10 06:28 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
Yeah..no kidding..
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: B1CUDA] #863246
11/26/10 06:42 PM
11/26/10 06:42 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
60 foot: 1.300
1/8th mile: 5.33
1/4 mile: 8.56
MPH: 158.96
I gathered the car just passed the 1/8th mile cone, and laid into it until the 1000 foot cone, where it got very loose again. I let out completely and pulled the chute. Game over.
Happy Thanksgiving!
You should have been in Vegas last weekend, Chris. Track was better than any I've ever seen and the air was about 2000'.
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobR] #863247
11/26/10 07:01 PM
11/26/10 07:01 PM
Orange County, Ca.
B1CUDA Offline
B1CUDA  Offline
Orange County, Ca.
I was there, just didn't bring the car. Yes, the track was great and the DA was the best I have ever seen. Just decided to sit the rest of the year out, as my business is going bonkers right now. Have a great holiday season!
Chris
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobR] #863248
11/26/10 07:42 PM
11/26/10 07:42 PM
SC
Greg Offline
Greg  Offline
SC
Bob,
If I was going to spend that kind of money on a transmission I would go with the liberty. The trick would be getting the clutch setup and the stick gears setup for a small tire car.
Even the best converter has some slippage on the top end. That is where you should be driving around the automatic car with a stick. Clutches are a lot more durable and reliable than a decade ago. This is why you are seeing more stick cars being built for the hemi shootouts.
If the rules state the stick cars can only have 4 gears that is alright. There are tricks to make that 4 speed run like a 5 speed!
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: Greg] #863249
11/26/10 09:54 PM
11/26/10 09:54 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
If the rules allow the Liberty, and you have to start from scratch, I wouldn't think of anything but the Liberty, and take the 50lb added weight. Lets face it the Liberty is a purpose built transmission, and can be had with just about ANY gear ratio combo you can think of. Clutch can be set up for track conditions, and NOTHING is cooler then dropping the clutch and rowing the gears.
69 GTX 68 Road Runner
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: JERICOGTX] #863250
11/26/10 10:49 PM
11/26/10 10:49 PM
sycamore,ohio
sycamore,ohio
there is only the 50 lbs. if you run them clutchless
there used to be a 100 lb penalty for the 5 speed liberty's, but they did change that since Liberty sponsors the class.
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobsProFab] #863251
11/27/10 12:10 AM
11/27/10 12:10 AM
ohio
all spooled up Offline
ohio
are you going to a 5 speed or a p glide
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: all spooled up] #863252
11/27/10 12:29 AM
11/27/10 12:29 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Another vote for the Liberty!!! Row some gears Boy!!!!!
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: BobsProFab] #863253
11/27/10 12:36 AM
11/27/10 12:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Seems like kind of a no brainer. But it sure might be a wallet beater
Re: How bad will a glide kill my 500 CI @ 3425 lbs. [Re: Al_Alguire] #863254
11/27/10 01:35 AM
11/27/10 01:35 AM
new jersey
gillman34 Offline
gillman34  Offline
new jersey
I have a Liberty 5 speed and a Bruno drive in the Dart now,replaced the glide with this combo when I went all motor.
Tight gear spacing keeps the 555 ci engine in it's power range.
I shift at 9200,with 4.88 rear and M/T 3062S 29.5x10.5 tires.
My car is 3660 race weight so it's heavy,and the engine makes it's power at high rpm,close to your combo.
BTW,you will probably need the Extreme 5 speed because of the weight of the car and the potential HP the Hemi 99 will make.
Let me know if I can help(call or pm)
Steve
