Page 2 of 3 1 2 3
Re: Should I Make Engine (440)This Winter's Project? [Re: tywebb2] #862843
11/25/10 01:13 AM
11/25/10 01:13 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Milling the heads .050" to get me to 74cc and then using the standard .039" head gasket would put me at 10.54:1 by my numbers. This would in effect be very close to .040" off the heads with a .027" head gasket...just a lot cheaper....right?
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862844
11/25/10 01:29 AM
11/25/10 01:29 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ive never used the cometics, But, from what I know/hear they can be used several times.
As far as fly cutting the pistons, that can be done without taking the pistons out., mike
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862845
11/25/10 12:12 PM
11/25/10 12:12 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Milling the heads will definitely help and some porting really helps. The pushrod pinch can be opened up a lot on the intake ports to really help flow!
Clay your valve reliefs and see how close you are to the back side if the fly cuts but most TRW are fine with the 2.14 valve.
According to some most of us should not be offering advice unless we are Pro racers (I'm a hobbiest racer) or engine builders so sorry if i'm out of line. The 509 where it is degreed now will like the added pop even more!
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862846
11/25/10 12:52 PM
11/25/10 12:52 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My old 440 block had trw 6 pack pistons, i ran RPM heads milled to 76cc and copper coated steel shim head gaskets. My cam was R280, 280/280 AT .050, .670/670 lift and that cleared fine.
I used shims to get the comp as high as possible because the cam was too big.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Should I Make Engine (440) This Winter's Project ? [Re: deaks] #862847
11/25/10 01:07 PM
11/25/10 01:07 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I think I am going to definately pull the heads, have them milled, have the guy I know do a little port work on them and then see what happens.
Is it safe to reuse the cometic MLS gaskets? I will probably just mill a little more off the heads and go with the standard .039" Felpros but had to ask.
I am just looking for a couple more tenths to get me into the 11.5's or a little deeper so I can race on an 11.5 index next year. That is my limit because I don't want to cage the car. This sounds like the ticket and budget friendly
'72 440 Cuda
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862848
11/25/10 01:40 PM
11/25/10 01:40 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
so buy my block advertised on here and problems solved...just build it bigger
Re: Should I Make Engine (440)This Winter's Project? [Re: tywebb2] #862849
11/25/10 05:31 PM
11/25/10 05:31 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Yes it would have the same compression but you would be losing a .012 of Quench.
Quench is your friend to help resist detonation when you raise the comp closer to the threshold. Wicth is what your doing.
Id keep the .047 quench , shave the heads .050 and reuse the Cometics. Its been done several times here by members of this board.
Further on quench, its been once tested by a associate of Vizard. On a 350 ,450 hp motor each .010 tighter quench = a 7hp increase. With the Same comp.
Your 440 could see more then 7 HP per .010 or not. So why throw that posibilty away and increase your detonation risks at the same time.
The www.kb-silvolite.com , calc that I like to use over the Wallace calc gives 11.07 comp with 74cc .03 gasket and 4cc reliefs.
I know, I know, they are 7cc and your cometic is .027 thick. The above will need recalculated, but its ball park.
If you click on the above link, look for Calculaters. mike
Re: Should I Make Engine (440)This Winter's Project? [Re: Sport440] #862850
11/25/10 05:40 PM
11/25/10 05:40 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Wouldn't the quench effect be virtually the same either way? The piston is still down in the hole .0205". The only difference is you are taking more off of the head which is made up by the thicker head gasket. So the combustion chamber of the head would still be the same distance away from the piston. Am I missing something here?
What is the ideal quench height? I am curious how far off I would be at .047"?
Can anyone confirm that they have reused Cometic MLS head gaskets without any problems? I am a little scared to do that.
'72 440 Cuda
Re: Should I Make Engine (440)This Winter's Project? [Re: tywebb2] #862851
11/25/10 05:59 PM
11/25/10 05:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
No with a .020 deck + .027 is .047 quench,
.020 deck + .039 is .059 quench.
These arent my rules but KB,s After .060 quench, the benifits drop off fast. KB uses the word forfeited after .060
So .060 would be the max .050 would be better and .040 better yet. After that things get way to close for the average home builder. Every piston deck height to head clearence should be checked.
Like Cab eluded to earlier, stock deck heights are not consistant from front to back and side to side. Im sure yours arent either, so that .020 deck may be .027 in some cyl,s. Because of that some builders would suggest you go no tighter then .045 to .050. I havent heard of any 440 block going tighter then .033 without contact Aluminum rods need greater clearences. mike
Re: Should I Make Engine (440)This Winter's Project? [Re: Sport440] #862852
11/25/10 06:23 PM
11/25/10 06:23 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I measured my pistons at .018 down, that's why i used shims to get a good quench.
best 60ft 1.36
Re: Should I Make Engine (440)This Winter's Project? [Re: deaks] #862853
11/25/10 06:44 PM
11/25/10 06:44 PM
UK
602heavy Offline
602heavy  Offline
UK
74cc chambers along with a .027" head gasket will net a comp ratio of 10.8 , sounds pretty good.
Some will use those cometics a number of times with no issues , can be a pain seperating the layers , cleaning & resealing , i would just go with a new set , the only gaskets i ever reused were the titan copper gaskets.
Re: Should I Make Engine (440)This Winter's Project? [Re: 602heavy] #862854
11/25/10 08:24 PM
11/25/10 08:24 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Your post says you want to cut some ET.
I think if you swap the .509 for a .557 solid you'll be happy (if you are running an auto trans). My
Re: Should I Make Engine (440)This Winter's Project? [Re: AAR-B4] #862855
11/25/10 11:27 PM
11/25/10 11:27 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Thanks for the recommendation but I am determined to get my car to an 11.5 or better with the MP 509 cam.
I am wondering....how much do you think I can gain by just having the heads milled vs. milling the heads and some light port work? The guy I know said he would just do a gasket match and clean up the bowls under the intake valves. He has a flow bench and said he would give me numbers before and after the work. I remember reading a long time ago that these heads are very good out of the box. I am just wondering if the porting would be a waste of time and to just worry about bumping up the compression?
'72 440 Cuda
Re: Should I Make Engine (440)This Winter's Project? [Re: tywebb2] #862856
11/26/10 12:57 AM
11/26/10 12:57 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
With your combo, the port match and bowl cleanup work of the Eddy head wont gain you anything worth your while,IMO. The milling alone, by far will be the best Bang for the buc. mike
Re: Should I Make Engine (440)This Winter's Project? [Re: Sport440] #862857
11/26/10 08:50 PM
11/26/10 08:50 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
What is the tightest p-to-v clearance I can get away with on the intake valve and still be safe?
'72 440 Cuda
Re: Should I Make Engine (440)This Winter? [Re: Cab_Burge] #862858
11/27/10 12:31 PM
11/27/10 12:31 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
They are .0205" down in the hole.
If I was you I would disassemble the short block and have the deck cut .010 to .015, depending on how much piston to cylinder wall clearnances you have now If your running .003 or more piston to wall clearnaces cut the deck .010 and reuse the head gaskets, do the math on that with your current head CC and see what that gets you for a compression ratio, check both KB pistons sight and Wallaces, they do not come up the same using the same specs on both sites If you have less than .003 piston to cylinder wall shoot for .000(zero) down in the hole, BTW, make sure you check every piston in every cylinder for its piston deck hieght, especially if you haven't already stock Mopar forged rods are not that close to each other on the lengths a lot of the time My message is to set the deck hieght of the block based on the highest pistons on each side, not just the (only) one you checked on one side of the block
I agree 100%
Re: Should I Make Engine (440)This Winter? [Re: 70blackfish] #862859
11/27/10 02:03 PM
11/27/10 02:03 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I really didn't feel like going into it that far. I just want to mill the heads to bump the compression up a bit. Looking in the old Mopar Engine book it says .090" of clearance is safe for an auto trans. Based on that I could take .030" off and pick up a half a point in compression. Like I said...all I need is another tenth or two in ET to have a solid 11.5 which is my limit because the car isn't caged.
'72 440 Cuda
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862860
11/27/10 08:41 PM
11/27/10 08:41 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
That MP number is way conservitive. The intake valve is opening from a rested seated position chasing the piston down the bore at its closest clearence.
You could probably go as tight as .020 and never have contact. I wouldnt go any tighter then .050 to .060 You will be fine with a .080 or .070 depending how far you want to mill your heads.
You still need to check your radial clearence. So far some has stated the 6 pac pistons are clearenced for 2.14 valves and some say they arent. Or was that you? Thats still up in the air for me, cause I dont know, mike
Re: Should I Make Engine (440)This Winter? [Re: Sport440] #862861
12/11/10 11:29 AM
12/11/10 11:29 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I called Jim Dowell at Racer Brown yesterday just to ask him where the compression "sweet spot" was for the 509 cam. After talking with him he said I would see very minimal gain bumping the compression up a half point. I think he worked it out to about 9hp which he said could potentially get me a tenth.
He said my biggest gain would be in a converter change. He said the 10" I am running now is no good. He suggested switching to an 8". I have an ATI that I used to have in the Cuda but pulled out because I didn't like it on the street. He said I could pick up as much as a few tenths switching to the 8". I am going to call ATI next week to see if tightening it up a little would help make it more street friendly while still helping me out at the track.
The other option would be a 9.5". I talked to Shawn at Dynamic and he said putting one of their 9.5" verts in would pick up 2-3 tenths over the 10". He also said the vert change should get me 1.5 60' times.
So it looks like the head milling project may be on hold depending on what ATI tells me. Or I could do both
'72 440 Cuda
Re: Should I Make Engine (440)This Winter? [Re: tywebb2] #862862
12/11/10 11:42 AM
12/11/10 11:42 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
So I guess racer brown advice discredits all the above?
Page 2 of 3 1 2 3
