Re: Valvesprings galling aluminum heads ???
[Re: Cab_Burge]
#862226
11/25/10 07:12 PM
11/25/10 07:12 PM
Posts: 4,221 New York
polyspheric
New York
Don't run just spring shims on any aluminum head
X2 - the entire valve & collar assembly flaps around on the head at high speed like a sparrow in a birdbath, and it will split the shim. If you're lucky it will spit it out, if not it gets caught between coils.
Boffin Emeritus
[Re: Stanton]
#862232
11/26/10 05:34 AM
11/26/10 05:34 AM
Posts: 5,875 communist bloc of new jersey
jamesc
So can I run just the spring in the cup or does there have to be a shim underneath to let things rotate?
no shim is required under the cup/locator. personally i wouldn't run springs against shims and certainly not on an aluminum head. imho if you need shims they go under the cup/locator
[Re: jamesc]
#862234
11/26/10 10:45 AM
11/26/10 10:45 AM
polyspheric
New York
X2 - under the cup, same surface area as the cup (not smaller). The spring ends should be ground off and polished so they don't try to eat the cup anyway.
Boffin Emeritus
[Re: Stanton]
#862236
11/26/10 09:44 PM
11/26/10 09:44 PM
Posts: 14,575 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
most of the Indy heads i sell dont get cups or locators. like Al said, unless the springs are mis-matched to the cam/rocker combo, this wont really cause any problems.
tens(hundreds?) of thousands of SBC heads are in service all over the world with the pocket machined into the casting being used to locate the spring on the head.
if the customer wants cups or locators, i will modify the heads to use them, no problem. i'll also use cups/locators on the more radical combinations that require a larger diameter spring than will fit inside the machined pocket of the Indy head.
attached is a pic of some 440-1's that were cut to accept a 1.740 OD cup/1.640 OD spring combo. not the best pic of the spring pads, but you should be able to get the drift.....
