Re: 8 3/4 - Yoke u-joint caps help [Re: W5Duster436] #86071
07/09/08 11:59 AM
07/09/08 11:59 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Don't use the Moroso caps. They often contact the driveshaft and create carnage.
Re: 8 3/4 - Yoke u-joint caps help [Re: CJK440] #86072
07/09/08 12:01 PM
07/09/08 12:01 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
maybe u could use the F*%$D 9" u-bolts. There are several diffrent sizes. used them on our dirt track cars and never had a failure.
Re: 8 3/4 - Yoke u-joint caps help [Re: mod5v] #86073
07/09/08 02:42 PM
07/09/08 02:42 PM
Indiana
W5Duster436 Offline OP
Indiana
Since I don't have the original bolts with me are they 1/4" bolts? If so I guess I can get some 1.75" 1/4-28 grade 8 cap screws and try them.
So in my above picture the length is around 1 7/8 total so I am assuming that half the cap is .5625 (1.126 diameter) subtracted from 1.875 (1 7/8 I measured) which leaves 1.312". I guess adding in the thickness of the cap and needing some space for the nuts will leave me to get 1.75" or 2" long bolts.
Sound right? Not sure the have 1.75" long cap screws but I guess I'll call around.
