8 3/4 posi question #86004
07/08/08 07:10 PM
07/08/08 07:10 PM
ohio
dodgedart416 Offline OP
ohio
Will any posi fit in any carrier? or are there specific posi's for specific carriers? Thanks
Re: 8 3/4 posi question [Re: dodgedart416] #86005
07/08/08 07:23 PM
07/08/08 07:23 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Hmmmm ... I was not aware of any Generous Motors part being able to fit in a 741, 742 or 489 case !
Re: 8 3/4 posi question [Re: dodgedart416] #86006
07/08/08 07:23 PM
07/08/08 07:23 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
8 3/4 SURE GRIP will fit any 8 3/4 case. Just use the side bearings for the sure grip unit. The outer diameter of the bearing races is the same but the cine inner diameter different.
GM posi's will not fit.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 8 3/4 posi question [Re: MoparforLife] #86007
07/08/08 07:42 PM
07/08/08 07:42 PM
ohio
ohio
Thanks Knows I guess I should have said sure grip
Re: 8 3/4 posi question [Re: dodgedart416] #86008
07/08/08 08:22 PM
07/08/08 08:22 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Yeah its a tuff croud here on sure grips and posi's. But actually back in the day, evrything was a posi in hotrod talk on the street. This was in the 60's and 70's, even the 80's. But at least they answered your question for you
