Re: 71 cuda pro touring project
[Re: SCATPACK 1]
#860063
11/30/11 09:06 AM
11/30/11 09:06 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
Great question!! The reason that the gills are glued in the fenders other than welded is that the Mig weld is a (hard weld) and expands at a different rate then the metal all around it. This is evident with dark colors (this car will be black) when the car is parked in the hot sun (like at a car show). The mig weld will show thru the paint. so the upper part where it is in direct sunlight of the car, roof, hood ,deck lid, upper fenders and quarters I use panel adhesive. Other benifits are no warpage and the repair is waterproof . This is why I also replaced my deck lid and my hood, the glue and seam sealer on the original panels are 40 yrs old or older and is hard too. The new panels have softer glue and expand and contract correctly. Anytime you are at a car show look close at black car in the sun you will see what I am talking about.If incorrectly done you will see these problems
[Re: NV69B7RR]
#860070
12/25/11 12:27 PM
12/25/11 12:27 PM
johnscudashop
Mrytle Beach SC
3 inch TTI headpipes installed, With the driveline angle at 1 deg instead of the factory 3 deg has created some clearance problems. The engine pipes hit the floor pan so some clearancing was in order. since this is a tuned system I will modify the car as much as possible without tweeking the tubes much.
[Re: johnscudashop]
#860071
12/26/11 04:51 PM
12/26/11 04:51 PM
Posts: 9,116 Falconer, NY
KatFysh
Falconer, NY
AWESOME progress and pics.. I' built a pro street Cuda back in 2000 and sold it a few years later. I now have another that I hope to start working on within the following year. I have had a few ideas in mind for it and now after looking through your postings, I have a few more.
I really like what you did with the rear valance and bumper. I also like the rear suspension setup you have, among many other things.
I originally thought of using a modern era Hemi engine but have decided against it {for now}. I'll probably go with the 400 bb I have and use a Powerjection efi kit..we'll see..
Keep up the GREAT work.. You have many people following along, even if we all don't reply..
When you decide to quit, THAT is the moment when you would've succeeded..
