Page 10 of 26 1 2 8 9 10 11 12 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #860014
10/06/11 08:47 PM
10/06/11 08:47 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
In place
Re: 71 cuda pro touring project [Re: johnscudashop] #860015
10/06/11 08:48 PM
10/06/11 08:48 PM
Mrytle Beach SC
Mrytle Beach SC
other side
Re: 71 cuda pro touring project [Re: johnscudashop] #860016
10/07/11 05:33 AM
10/07/11 05:33 AM
QLD Australia
Keith Black® Offline
QLD Australia
Looking good!
Re: 71 cuda pro touring project [Re: Keith Black®] #860017
10/07/11 06:44 AM
10/07/11 06:44 AM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
What brand epoxy are you using? Can you provide details on the media blasting you did (plastic, sand, pressure pot or cabinet, etc.)?
Re: 71 cuda pro touring project [Re: larry4406] #860018
10/07/11 12:25 PM
10/07/11 12:25 PM
Mrytle Beach SC
Mrytle Beach SC
Hello, I use Dupont epoxy primer , Followed by 2K after body work. SEM 39747 panel adhesive and 80 grit aluminum oxide bast media out of a industrial pressure pot and Blasting Room. More info at www.jcautorestoration.com (Thanks John & Chris)
Re: 71 cuda pro touring project [Re: johnscudashop] #860019
10/11/11 08:14 PM
10/11/11 08:14 PM
Mrytle Beach SC
Mrytle Beach SC
With the clutch pedal bottoming out inside the clutch master cylinder, I decided to make a ajustable stop for it. Also I made a shifter bracket because the shifter was too far foward andsat too high. Now its angled back 20 deg. I will have to move the shifter boot and ring back also.
Re: 71 cuda pro touring project [Re: johnscudashop] #860020
10/11/11 08:15 PM
10/11/11 08:15 PM
Mrytle Beach SC
Mrytle Beach SC
welding and fab on the bracket
Re: 71 cuda pro touring project [Re: johnscudashop] #860021
10/11/11 08:16 PM
10/11/11 08:16 PM
Mrytle Beach SC
Mrytle Beach SC
Shifter bracket
Re: 71 cuda pro touring project [Re: johnscudashop] #860022
10/11/11 08:17 PM
10/11/11 08:17 PM
Mrytle Beach SC
Mrytle Beach SC
Shifter angled back 20 deg. Makes for a more comfortable shift.
Re: 71 cuda pro touring project [Re: johnscudashop] #860023
10/15/11 10:50 AM
10/15/11 10:50 AM
Mrytle Beach SC
Mrytle Beach SC
I made some tubes from 1 inch conduit to run my wires though (to hide some of the wires in the engine compartment). Other items finished was mocked up the gas pedal and throttle cable for the fuel injection finish welding the trans tunnel.
Re: 71 cuda pro touring project [Re: johnscudashop] #860024
10/18/11 05:33 PM
10/18/11 05:33 PM
Mrytle Beach SC
Mrytle Beach SC
Modification of the rear seat to fit the rear roll bar down tubes.
Re: 71 cuda pro touring project [Re: johnscudashop] #860025
10/18/11 05:34 PM
10/18/11 05:34 PM
Mrytle Beach SC
Mrytle Beach SC
Clearance around the roll bar
Re: 71 cuda pro touring project [Re: johnscudashop] #860026
10/18/11 05:35 PM
10/18/11 05:35 PM
Mrytle Beach SC
Mrytle Beach SC
Added 1/4 CRS round bent it 90 degrees then welded in.
Re: 71 cuda pro touring project [Re: johnscudashop] #860027
10/18/11 05:37 PM
10/18/11 05:37 PM
Mrytle Beach SC
Mrytle Beach SC
Rear seat is now ready for padding and covering
Re: 71 cuda pro touring project [Re: johnscudashop] #860028
10/18/11 10:35 PM
10/18/11 10:35 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Looks like you're clicking along. The conduit for the wires was a good idea.
Re: 71 cuda pro touring project [Re: JDMopar] #860029
10/24/11 04:30 PM
10/24/11 04:30 PM
Mrytle Beach SC
Mrytle Beach SC
I took the bumpers and deleted the front license plate area and filled in the buper bolt holes . Now a 3/8 studs reside in its place. This will give my bumpers a smooth look
Re: 71 cuda pro touring project [Re: johnscudashop] #860030
10/24/11 04:31 PM
10/24/11 04:31 PM
Mrytle Beach SC
Mrytle Beach SC
License plate area filled in with 3/32 steel plate
Re: 71 cuda pro touring project [Re: johnscudashop] #860031
10/24/11 04:32 PM
10/24/11 04:32 PM
Mrytle Beach SC
Mrytle Beach SC
Front of the bumper
Re: 71 cuda pro touring project [Re: johnscudashop] #860032
10/24/11 04:34 PM
10/24/11 04:34 PM
Mrytle Beach SC
Mrytle Beach SC
Installed on the rear. I will have to shave the rear bumper to tighten up gap between the body and bumper.
Re: 71 cuda pro touring project [Re: johnscudashop] #860033
10/26/11 05:34 PM
10/26/11 05:34 PM
Mrytle Beach SC
Mrytle Beach SC
Side marker delete
