Page 9 of 26 1 2 7 8 9 10 11 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #859994
09/19/11 08:55 PM
09/19/11 08:55 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
Thanks to Stefan at Elite custom autobody for the great deal on the AMD trunk lid
Re: 71 cuda pro touring project [Re: johnscudashop] #859995
09/23/11 11:54 AM
09/23/11 11:54 AM
Mrytle Beach SC
Mrytle Beach SC
I added the front roll bar supports and floor plates. I was carefull because I want to be able to use the stock door panels and kick panels. The stock parking brake assembly will be replaced with a more convinient floor lever unit.I spent some time modifying the dash cage, welded up the ash tray area (as it is not needed) and cut the frame for the front roll cage tubes.
Re: 71 cuda pro touring project [Re: johnscudashop] #859996
09/23/11 11:56 AM
09/23/11 11:56 AM
Mrytle Beach SC
Mrytle Beach SC
Ash tray delete. Looks cleaner without it
Re: 71 cuda pro touring project [Re: johnscudashop] #859997
09/28/11 11:21 AM
09/28/11 11:21 AM
Mrytle Beach SC
Mrytle Beach SC
After looking at some weld in cage bungs, I decided to make my own from some 1 3/4 CRS steel I had here at the shop. I want to make the side bars and rear cross brace removable. Careful attention was made so the door panels and seats clear the roll cage tubes.
Re: 71 cuda pro touring project [Re: johnscudashop] #859998
09/28/11 11:22 AM
09/28/11 11:22 AM
Mrytle Beach SC
Mrytle Beach SC
RH bar shot
Re: 71 cuda pro touring project [Re: johnscudashop] #859999
09/28/11 11:22 AM
09/28/11 11:22 AM
Mrytle Beach SC
Mrytle Beach SC
LH cage bar picture
Re: 71 cuda pro touring project [Re: johnscudashop] #860000
09/28/11 11:23 AM
09/28/11 11:23 AM
Mrytle Beach SC
Mrytle Beach SC
Rear cross brace picture
Re: 71 cuda pro touring project [Re: johnscudashop] #860001
09/28/11 11:31 AM
09/28/11 11:31 AM
Mrytle Beach SC
Mrytle Beach SC
These are just tacked in place. I plan on fully welding them(probably with my Tig, after I pull it down for paint and put it on the rotisserie, this way I can weld fully around the tubes.
Re: 71 cuda pro touring project [Re: johnscudashop] #860002
09/30/11 11:15 AM
09/30/11 11:15 AM
Mrytle Beach SC
Mrytle Beach SC
RH side bar (notice it doesn't interfere with the door panel)
Re: 71 cuda pro touring project [Re: johnscudashop] #860003
10/02/11 03:42 PM
10/02/11 03:42 PM
Mrytle Beach SC
Mrytle Beach SC
I deleted the bumper gaurd areas from the rear valance. This makes for a much cleaner look.I changed the whole look of the back of the car.
Re: 71 cuda pro touring project [Re: johnscudashop] #860004
10/02/11 03:43 PM
10/02/11 03:43 PM
Mrytle Beach SC
Mrytle Beach SC
Marked for cut out.
Re: 71 cuda pro touring project [Re: johnscudashop] #860005
10/02/11 03:43 PM
10/02/11 03:43 PM
Mrytle Beach SC
Mrytle Beach SC
cut out
Re: 71 cuda pro touring project [Re: johnscudashop] #860006
10/02/11 03:46 PM
10/02/11 03:46 PM
Mrytle Beach SC
Mrytle Beach SC
I made sure I tack welded the areas in place while the valance was bolted to the car. This way there is no fitting problems later.
Re: 71 cuda pro touring project [Re: johnscudashop] #860007
10/06/11 05:51 PM
10/06/11 05:51 PM
Mrytle Beach SC
Mrytle Beach SC
I media blasted the fenders, header panel rear valance and dash frame, inside and out. There was no suprises, just some minor work. I Epoxy primed right away.
Re: 71 cuda pro touring project [Re: johnscudashop] #860008
10/06/11 05:52 PM
10/06/11 05:52 PM
Mrytle Beach SC
Mrytle Beach SC
Fenders fresh out of the Media Blaster
Re: 71 cuda pro touring project [Re: johnscudashop] #860009
10/06/11 05:55 PM
10/06/11 05:55 PM
Mrytle Beach SC
Mrytle Beach SC
Epoxy primer (dash cage and Rear valance)
Re: 71 cuda pro touring project [Re: johnscudashop] #860010
10/06/11 05:56 PM
10/06/11 05:56 PM
Mrytle Beach SC
Mrytle Beach SC
Fenders in epoxy primer
Re: 71 cuda pro touring project [Re: johnscudashop] #860011
10/06/11 05:57 PM
10/06/11 05:57 PM
Mrytle Beach SC
Mrytle Beach SC
Fenders inside also blasted and in epoxy.
Re: 71 cuda pro touring project [Re: johnscudashop] #860012
10/06/11 08:46 PM
10/06/11 08:46 PM
Mrytle Beach SC
Mrytle Beach SC
I added the fender gill sections. I glued these in with SEM panel adhesive to eliminate warpage from welding and to elinimate the dreaded mig weld see thru in the paint.
Re: 71 cuda pro touring project [Re: johnscudashop] #860013
10/06/11 08:46 PM
10/06/11 08:46 PM
Mrytle Beach SC
Mrytle Beach SC
Panel adhesive application
