225/70/14 on a stock steel sbp Mopar wheel #85990
07/08/08 06:46 PM
07/08/08 06:46 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Have a set of stock steelies and want to put some tires on the wheels just to get the car up on the trailer and home.Have a pair of 225/70/14 tires laying around. Will these wheels work on the stock steel wheels?
What about if I were to put the car on a dolly(rear wheels on the ground) would the tires indicated above be ok on those rims?
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: SPWC] #85991
07/08/08 06:47 PM
07/08/08 06:47 PM
a cornfield near you
BlakDak Offline
BlakDak  Offline
you shouldn't have any problems as long as the tires are in good shape.
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: SPWC] #85992
07/08/08 06:49 PM
07/08/08 06:49 PM
SPWC Offline OP
SPWC  Offline OP
Sorry,I dont know if I specified,the wheels are the skinny small bolt pattern A body wheels on a 72 Swinger
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: SPWC] #85993
07/08/08 06:50 PM
07/08/08 06:50 PM
BlakDak Offline
BlakDak  Offline
yah, they should be fine as long as the tires are good.
I think the rims are 4 or 5" wide on the narrowest ones.
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: BlakDak] #85994
07/08/08 07:02 PM
07/08/08 07:02 PM
SPWC Offline OP
SPWC  Offline OP
Tires are in good condition...Thanks for the input!
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: SPWC] #85995
07/08/08 07:09 PM
07/08/08 07:09 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Only if it a 5.5" wide SBP steelie, even then it's not recommened to go more than 215-70x14.
Most SBP steelies are only 4.5" wide, largest recommended tire is 185-70x14.
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: B5 Bee] #85996
07/08/08 07:20 PM
07/08/08 07:20 PM
BlakDak Offline
BlakDak  Offline
He just wants to get it home on them, not run a race.
For what its worth, I had 235/60/14's on stock small bolt pattern wheels on a car I drove daily.
So towing it on a dolly, or rolling it onto a trailer won't be a problem.
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: BlakDak] #85997
07/08/08 10:41 PM
07/08/08 10:41 PM
Parsons (SouthEast) Kansas
funkyjbp Offline
mopar addict
funkyjbp  Offline
mopar addict
i ran 225/70/14s on small bolt pattern ralleye wheels which i think were 5.5 inches wide. they cleared on all four corners of a 70 dart swinger and looked damn good too. no significant bulging or goofy tire wear observed. jp in ks.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: funkyjbp] #85998
07/09/08 10:46 AM
07/09/08 10:46 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
My friend ran 245/60-14 on 14X5.5 steelies in back.
Re: 225/70/14 on a stock steel sbp Mopar wheel [Re: SPWC] #85999
07/09/08 10:49 AM
07/09/08 10:49 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
That's what I used on a 69 coronet w/ stcok 14 magnums. looked good.
