Re: !!!! Update broke the race car with rearend pics!!!!
[Re: Mopar_Mike]
#859590
11/22/10 04:16 PM
11/22/10 04:16 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
I've broken plenty of 8.75 ring gears but since I went to the aluminum carrier and the pro gear I haven't broken anything. I'm going to put a new pro gear in before the new stroker engine goes in though.
[Re: cgall]
#859592
11/22/10 06:03 PM
11/22/10 06:03 PM
Guitar Jones
I could only get 50-100 runs on a set of street gears, had to pull axles and check ring gear teeth a couple times a year. That will get you by while you save for a Dana, I put a pro gear in my 8-3/4 in 1997 and it's holding up fine. Pro gears are hard to find nowadays, tho.
Strange still sells them, I just ordered one but they only come in one ratio, 4.86:1
[Re: mopar65]
#859593
11/22/10 09:18 PM
11/22/10 09:18 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I don't even see ONE billet cap in this thread?!?! ![](/ubbthreads/images/graemlins/shruggy.gif) Do you guys just run a stock 8 3/4 rear with a gearset?
CrAzYMoPaRGuY
