Re: 427 small block
[Re: 416challenger]
#857241
11/22/10 10:48 PM
11/22/10 10:48 PM
Posts: 226 lino lakes,MN
onebaddakota
lino lakes,MN
All this is based on the assumption of using the same cam. In my situation, going to a 4.125 crank from a 4" crank will now allow me to run a bigger cam and retain the same vacuum for street driving. The bigger cam should now help the HP side of the equation. I think this is especially true with motors that are RPM limited due to a hydraulic roller set up.
10.56 at 125.6, with a 1.43 60 ft.
E85, Hyd. Roller 410 magnum,full exhaust, 3500 race weight.
