Production 6.4L 392 Hemi engine specs
#855165
11/16/10 12:09 PM
11/16/10 12:09 PM
Posts: 9,719 Home
SRT6776
I hate internal combustion engines!
Home
Dragstrip video http://www.youtube.com/watch?v=ZFbxZZtywZ0Challenger SRT8 392 engine specs Type and Description 90-degree V-type, liquid-cooled Displacement 392 cu. in. (6,424 cu. cm) Bore x Stroke 4.09 x 3.72 (103.9 x 94.5) Valve System Pushrod-operated overhead valves, 16 valves with sodium-filled exhaust valves and hollow stem intake valves, 16 conventional hydraulic lifters, all with roller tips Fuel Injection Sequential, multi-port, electronic, returnless; automatic features Fuel Saver mode Construction Deep-skirt cast-iron block with cross-bolted main bearing caps, aluminum alloy heads with hemispherical combustion chambers Compression Ratio 10.9:1 Power (estimated SAE net) 470 bhp (351 kW) @ 6,000 rpm (73.4 bhp/L) Torque (estimated SAE net) 470 lb.-ft. (637 N•m) @ 4,200 rpm Max. Engine Speed 6,400 rpm (electronically limited) Fuel Requirement Premium 91 octane (R+M)/2—recommended Oil Capacity 7 qt. (6.6L) Factory Oil Fill 5W-40 Synthetic Coolant Capacity 14 qt. (13.25L) Emission Controls Dual close-coupled three-way catalytic converters, quad-heated oxygen sensors and internal engine features(a) Max. Gross Trailer Weight Not rated for trailer-tow EPA Fuel Economy mpg (City/Hwy) TBD Challenger SRT8 392 DIMENSIONS AND CAPACITIES Wheelbase 116.0 (2,946) Track, Front 63.0 (1,603) Track, Rear 63.1 (1,604) Overall Length 197.7 (5,023) Overall Width 75.7 (1,923) Overall Height 57.1 (1,449) Ground Clearance 4.8 (122.2) Frontal Area, sq. ft. (sq. m) 25.6 (2.37) Drag Coefficient 0.356 Curb Weight, lb.Est. 4,160 (automatic) 4,170 (manual) Weight Distribution, percent F/R 54.4/45.6 (automatic) 54.6/45.4 (manual) Fuel Tank Capacity Gal.(L) 19 (71.9)
Re: Production 6.4L 392 Hemi engine specs
[Re: bwdst6]
#855167
11/16/10 12:21 PM
11/16/10 12:21 PM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
Man I'd like to get a hold of one of those engines. Imagine 13.5to1 compession, solid roller cam, 1050 dommy, 1 7/8 headers, cnc ported heads in a '69 Dart or 'cuda. Would be very fun and would get attention!
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: SRT6776]
#855168
11/16/10 12:30 PM
11/16/10 12:30 PM
Posts: 2,826 NY usa
540challenger
NY usa
did i read that right 470bhp?? so how much hp from the crank???
[Re: SRT6776]
#855171
11/16/10 01:47 PM
11/16/10 01:47 PM
Posts: 3,363 DTW
drmopar
DTW
I know someone at Dyno. Engine is capable of 525 HP with a tune and headers. They had a hard time meeting pollution standards at idle, so they had to pull some timing out of it. With a diablosport tune, the 392 should make 500-510 easy. Should motivate the big girl in the 12.20's with ease, as the one car already went 12.40's. MPH is not so great though at 110.
-------------------- RM27H9G 4 speed F8/tan guts RS27L9G auto B5/black guts WM23H9G auto F5/green guts 2021 Challenger 392 Indigo/black guts 2019 Charger Daytona R/T F8 on black 2018 Ram Sport Hemi 4x4
[Re: bwdst6]
#855172
11/16/10 02:52 PM
11/16/10 02:52 PM
Jacob Pitt
Mansfield, Tx
Sure, then you would get summarily trounced from anyone running a 69 Dart or Cuda with a second gen hemi running 13.5:1, solid roller, 1050 dom...
But you would get all kinds of attention!
Not so sure that everyone with a second gen hemi would beat it. I've seen some pretty dang slow hemi cars. Shoot the guys running the new Challengers in stock have already run 9.50's, with stock heads, crank, ect.
[Re: bwdst6]
#855174
11/20/10 07:42 PM
11/20/10 07:42 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
So what happened to the aluminum block we were promised would be in it?
[Re: HotRodDave]
#855175
11/21/10 02:38 AM
11/21/10 02:38 AM
Posts: 485 Raleigh, NC
j.mcconnell
Raleigh, NC
you mean stockER heads. doubt they take them straight off the assembly line. none the less, the package has great potential
