Re: Leaf Spring Restoration
[Re: jrwoodjoe]
#853564
11/14/10 09:39 PM
11/14/10 09:39 PM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
My kid had the ones in his 62 300 rearched and a leaf added.That was 10 years ago.They are better than new.His were like 110 for the pair.Rocky
Chrysler Firepower
[Re: therocks]
#853565
11/15/10 02:47 AM
11/15/10 02:47 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
Ive heard that since leaf springs are made from memory steel, they will just re-flatten out if they arn't properly re-arched using the method called reanealing (sp?) Im not sure of the process but someone will probably chime in.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: mopars_1]
#853566
11/15/10 07:23 AM
11/15/10 07:23 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
The two ways to re-arch are explained here. I know a racer that used the cold method. When going from dirt to pavement and back, he would pull the springs at the track and beat the with a hammer and wood blocks till he had the height he wanted. Other racers would laugh at first until he won the race. He was a real racer that did it all, build the car and drove. He had 1100 FEATURE wins in his career, was the guy to beat in Super Mods, even ran the Indy 500 a few years and won 1 Cart race with a 9 year old car, Offy motor and little budget.
[Re: mopars_1]
#853567
11/15/10 10:59 AM
11/15/10 10:59 AM
Posts: 343 S.E.Mich
drew72
S.E.Mich
If they were made from "memory metal" than why wouldn't they go back to the original arch they had in the very first place?
[Re: drew72]
#853568
11/15/10 11:12 AM
11/15/10 11:12 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I always thought the reason they lost arch was because the metal had fatigued after so many flexes, and was just worn out. however, they could be re-arched, and then replace a few leaves with new ones and they were good as new.
The local shop that did the ones for the packards, did it that way, he'd replace 2 or 3 leaves and just re-arch the main leaf for the factory height.
**Photobucket sucks**
[Re: burdar]
#853571
11/15/10 02:01 PM
11/15/10 02:01 PM
Posts: 15,487 Florida
scratchnfotraction
I have always just add another leaf to the stock spring pack most lift will come from a main leaf with the eys cut off(cut wheel/sawzall-no heat) most times I just add the 2nd leaf from another set of springs cheap ez and still rides good ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: burdar]
#853572
11/15/10 05:13 PM
11/15/10 05:13 PM
therocks
Niles , Ohio
budar if that guy told you that he dosent know crap.My kids 300 is a heavy car.His were rearched at least 10 years ago.They still sit as high as when he did them.He added an extra leaf for stiffness.The car has a ton of miles both street and strip.Rocky
Chrysler Firepower
[Re: scratchnfotraction]
#853575
11/16/10 09:35 AM
11/16/10 09:35 AM
therocks
Niles , Ohio
The place we used had a set on new springs on the shelf for my 57 Chrysler a few years ago.Both mains were snapped on it.When they rearch they reclamp the springs and they are all together.The bushings should be replaced.I use poly bushings in ours.Unless you are doing a 100 point resto just spray them when you get them back.Rocky
Chrysler Firepower
[Re: therocks]
#853576
11/16/10 09:45 AM
11/16/10 09:45 AM
70Cuda383
Marysville, O-H-I-O
There's the catch right there! you're both right!!
if all you do is re-arch the old worn out, fatigued springs, yes, they will sag again, because the metal is weak, worn out, tired, fatigued, and it will sag back down.
but, if you re-arch, AND add a leaf, or replace a leaf, with new, fresh metal that is NOT weak, then the springs will not sag back down.
#853578
11/16/10 03:41 PM
11/16/10 03:41 PM
therocks
Niles , Ohio
I even added an extra main to my new SS springs on my 65.I cut the main down from the old SS springs.Rocky
Chrysler Firepower
