Re: stealth head cracked
[Re: Quicktree]
#852856
11/15/10 01:45 AM
11/15/10 01:45 AM
Posts: 4,323 NY NY
340duster340
NY NY
sorry to hijack the thread, but is anyone running the pro-comp heads?
i would love to see one of the mopar mags do a chineese 440 build .... only thing American made would be the block.
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
[Re: 340duster340]
#852857
11/15/10 07:22 AM
11/15/10 07:22 AM
Quicktree
do you love the chinese?
[Re: 340duster340]
#852859
11/15/10 08:57 AM
11/15/10 08:57 AM
Challenger 1
Cincinnati, Ohio
[Re: 340duster340]
#852860
11/15/10 10:52 AM
11/15/10 10:52 AM
Posts: 591 Champion City
The Sphinx
Champion City
They did, not sure if the cheap valve in the cheap aluminum head broke, or the cheap rocker arm broke, or the cheap eagle connecting rod broke or the cheap aluminum water pump housing with it's restrictive ports caused the thermo-nuclear meltdown.
[Re: The Sphinx]
#852861
11/15/10 01:41 PM
11/15/10 01:41 PM
Posts: 5,080 organ
maximum entropy
organ
situation deteriorating, over?
[Re: topside]
#852863
11/15/10 03:14 PM
11/15/10 03:14 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
...I really like the idea of a stock-looking aluminum head with good architecture...
I wonder how hard it would be to program a CNC to make the Eddies look like a '906?
[Re: @#$%&*!]
#852864
11/15/10 04:33 PM
11/15/10 04:33 PM
Posts: 75,282 A gulag near you.
JohnRR
A gulag near you.
Not very , but you then would need to ADJUST the surface to LOOK like cast iron.
[Re: topside]
#852866
11/15/10 07:20 PM
11/15/10 07:20 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
If you're going to use Stealth heads then 1) buy them unported and leave them like that or 2) buy them with the CNC porting done. Brandon has replaced the cracked heads so have him stand behind the one you are going to use on your engine. If one breaks and you have had your LOCAL guy do the porting you'll be that much more in the hole to have one head re-worked.
dstryr, since 1986.
[Re: 70Cuda383]
#852870
11/16/10 01:31 AM
11/16/10 01:31 AM
Posts: 5,467 So Cal
Sinitro
So Cal
why are they cracking? too much power? un-true surfaces being clamped down causing too much flex? or are they simply too brittle?
anyone done any analysis on them to find out why they've cracked?
They crack due to an ineffective QA process in China. In China it is pertinent to have a local QA inspection team that monitors the entire process from raw material procurement to the actual casting.. Without this and a tite audit process, all bets are off.
The China sources will do all sorts of short cuts & tricks when they are not titely monitored and controlled..
We have been sourcing electronic components from China for over 20 years with an average annual $ value of >$10 million. So yes we know something about the Chinese system & culture..
Just my $0.02...
[Re: IcorkSOAK]
#852872
11/16/10 06:24 AM
11/16/10 06:24 AM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
With a few exceptions, Stealth heads only fool non-expert folks, who are almost all just as easily fooled by any of the other aluminum heads when painted with a good coat of Hemi orange. All it takes is a quick glance along the intake manifold or lower headbolt bosses for a Moparts member or a savy Mopar-knowledgable buff to spot the Stealths. Overall, for the money, they are a great head.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#852873
11/16/10 09:52 AM
11/16/10 09:52 AM
Posts: 2,826 NY usa
540challenger
NY usa
True but for the other 90% of the car guys "non-mopar" they think 318's are big blocks so if they do see a difference tell tell them its special mopar head desigh of a fuelie head
[Re: 540challenger]
#852874
11/16/10 01:26 PM
11/16/10 01:26 PM
jbc426
West Coast, USA
Yah, especially those 'big block" 318 poly motors.... Here's a "before paint" shot of my Indy EZ's.
[Re: jbc426]
#852875
11/16/10 01:31 PM
11/16/10 01:31 PM
jbc426
West Coast, USA
Yah, especially those 'big block" 318 poly motors. Here's a before paint shot of my Indy EZ's
...and here's a shot of my "stealth" Indy EZ's.
