Re: stealth head cracked
[Re: moparpilot1]
#852818
11/13/10 09:38 PM
11/13/10 09:38 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Almost called you yesterday to see how you made out. I guess you haven't heard back from Brandon yet. Hope everything works out.
[Re: Triple Threat]
#852821
11/14/10 06:18 AM
11/14/10 06:18 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
why are they cracking? too much power? un-true surfaces being clamped down causing too much flex? or are they simply too brittle?
anyone done any analysis on them to find out why they've cracked?
**Photobucket sucks**
[Re: The Cuda Guy]
#852824
11/14/10 10:42 AM
11/14/10 10:42 AM
Posts: 625 Florida-West Coast
Thor500
Florida-West Coast
Posts like this make me very nervous! I have a set of cnc stealths Im putting on my 493.
Don
You should probably not use those, PM me I might take em off your hands, just to help you out. ![](/ubbthreads/images/graemlins/stirthepot.gif)
[Re: Thor500]
#852825
11/14/10 10:51 AM
11/14/10 10:51 AM
Posts: 1,015 Down South
DaKuda
Down South
Guy here had a brand new set crack and blow head gaskets on the same run. They sent him new heads and told him to torque them to like 55ft.lbs. Said they dont need to be torqued like a set of Edelbrocks or Indy's. To me that says the material must be cheaper quality and softer...??? For what its worth, he did torque them to 55ftlbs. and they are working fine....for now.
[Re: DaKuda]
#852827
11/14/10 11:11 AM
11/14/10 11:11 AM
70Cuda383
Marysville, O-H-I-O
if they were softer, they wouldn't crack, they would deform, warp, bend, etc. soft metal does not crack, hard metal does.
[Re: moparpilot1]
#852829
11/14/10 01:30 PM
11/14/10 01:30 PM
Posts: 5,080 organ
maximum entropy
organ
i had a set crack a couple of years ago. both heads cracked badly, and in the same places. my guess is the heat treat was incorrect. 440source sent new heads, and it made it through a full season.
[Re: Quicktree]
#852832
11/14/10 02:20 PM
11/14/10 02:20 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
you guys could have bought some eddy's and been way ahead of the game. enjoy the chinese quality.....
I have Indys on my race motors. I bought Stealths because I can paint them and they look totally stock. IF they made Eddies that looked stock on the outside I would have bought them in a second.
For now the Stealth is the only game in town if you want aluminum heads that look stock. It wasn't really a price thing with me, it was the visual appeal they have for my resto cars. I will say though that they are getting new valves, springs, keepers, and a thorough going through before they get bolted on my engine. I essentially bought them for the casting.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: moparniac]
#852834
11/14/10 02:35 PM
11/14/10 02:35 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Wonder why he didn't tell customers that from the start.... Then say send em back and only torque new ones to 55!
My Stealth heads came with specific torque instructions that said 60 ft/lbs with ARP lube, or 70 ft/lbs with 30 wt. oil. I was using 30 wt., so went to 70 lbs in (3) incremental steps. No problems here. These were shipped to me in Dec. '09, have approx. a thousand miles on them now, with plenty of trips to 6500 RPM, no issues.
[Re: Quicktree]
#852835
11/14/10 02:43 PM
11/14/10 02:43 PM
Challenger 1
Cincinnati, Ohio
![](/ubbthreads/images/graemlins/laugh2.gif)
