Re: No spark [Re: way2fast] #852004
11/14/10 08:47 PM
11/14/10 08:47 PM
I'm showing #1 & #3 would be getting fire & w the "point" of the pentastar connector which is #1 @ 9o'clock. #2 would be at the top and #3 would be to it's right (still on top) and #4 would be on the bottom under #2 and #5 would be to its right on the bottom under #3. 4&5 go to the dist. #2 to the coil pri neg. #1 (the point) is the main power to the ECU and #3 is the "start" pin on a 5 pinner. we've r&r'd everything, We gotta find the "open".
Re: No spark [Re: RapidRobert] #852005
11/14/10 09:06 PM
11/14/10 09:06 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
looking at my haynes i've got conflicting schematics one diagram shows exactly how you said. and the big one in the back of the book shows 5 to the BR and 4 to coil negative. 2 and 3 to the distributor connector. and 1 to the BR
Go Fast and Swerve!
Re: No spark [Re: scratchnfotraction] #852006
11/15/10 05:15 PM
11/15/10 05:15 PM
P
Paul_Fancsali Offline
P
Points or pertronix never a better way. Got sick of Mopar ELEC due to all the crap that makes it fail. Now I use it as backup and never had to in years on three cars
Re: No spark [Re: Paul_Fancsali] #852007
11/15/10 05:18 PM
11/15/10 05:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: No spark [Re: stumpy] #852008
11/15/10 11:52 PM
11/15/10 11:52 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
I'm going through each and every wire on the ignition circuit and will figure this out!!!!!!!
Can anyone tell me should pin 4 or 5 on the ECU have power with ignition to start or run??? the ohms check showed good. and the other 3 had power.
freeeeeeeaaaaackin' truck
Go Fast and Swerve!
Re: No spark [Re: RapidRobert] #852009
11/15/10 11:57 PM
11/15/10 11:57 PM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
did that..... no sparky.
do we have fire at the coil primary positive terminal w the key turned to "start".
yes ... lower voltage in run and more in start (this is how it should be ...correct?)
Go Fast and Swerve!
Re: No spark [Re: way2fast] #852010
11/16/10 12:19 AM
11/16/10 12:19 AM
4 & 5 are connected to the dist & would have no power. they only rec a slight (seperate from the coil/ballast) self generated signal from the dist which makes the ECU ground the #2 wire from the coil neg pri thru the ECU case itself to ground on the fender. EDIT yes lower voltage in run as it's going thru the ballast & being reduced. Backing up a bit, you have fire at the coil positive and neg primaries in start and morse Code grounding the neg to ground did not make the coil secondary wire 1/4" from ground produce a spark?? If so that sounds like the coil secondary is out (no continuity). Do you have a volt/ohm meter? If so take all wires off of the coil and set the ohm scale to K (x 1000) so if you get (9) you have 9000 ohms. check between the center terminal and either one of the small primary terminals but it hit me that we just replaced the coil (& everything else). Stay on it we'll get it
Re: No spark [Re: RapidRobert] #852011
11/17/10 01:25 AM
11/17/10 01:25 AM
Southwest
way2fast Offline OP
way2fast  Offline OP
Southwest
Started completely over, undid all conections, took sand paper to all ground points and connectors ... reset crank to zero and set distributor to #1. checked firing order-OK.....turned over and backfired!!!! bingo we gots spark!!!
turned distributor a hair and WWWWWWWOOOOOOOHOOOOO!!! She sounds Gooooooood!!!
bad connection some where ... damn Gremlins!!
So next day off I'll be timing her up and adjusting the carb.
Go Fast and Swerve!
Re: No spark [Re: way2fast] #852012
11/17/10 02:13 AM
11/17/10 02:13 AM
I felt that all the way over here. Any idea on which connection was dirty? Now all you need to do is to purchase a set of pulleys & get her on the road
