Re: Cam Question
[Re: Mr.Yuck]
#851171
11/16/10 05:12 PM
11/16/10 05:12 PM
Posts: 6,570 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
The 484 cam (if it's the old style) can be a dog in the wrong combo. I had a similar set-up in a 440 coronet w/ 3.55's. The car sounded great and ran like heck after 3500rpm. It had no low end. I was running a 175 convert and yanked the cam and went w/ the summit 488, it ran much much better.
What did you have it dialed in at?
Kevin
Re: Cam Question
[Re: Twostick]
#851172
11/16/10 05:37 PM
11/16/10 05:37 PM
Posts: 15,487 Florida
scratchnfotraction
I want a hughes whiplash for my 440 its got the lumpy sound and is made to work with low comp has an early intake closeing to build cyl pressure and not kill off low end torque works with stock verter and 3.23s would be good for the street great cruzing cam with some pop for red light to red light action a more modern cam just for a low CR street engine would be the wize choise,IMHO my ![](/ubbthreads/images/graemlins/Twocents.gif)
Re: Cam Question
[Re: scratchnfotraction]
#851173
11/16/10 05:41 PM
11/16/10 05:41 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
my
There's no magic in a "whiplash" cam. Sorry I couldn't help it.
Re: Cam Question
[Re: goldmember]
#851174
11/16/10 05:47 PM
11/16/10 05:47 PM
scratchnfotraction
I know ![](/ubbthreads/images/graemlins/bow.gif) but it is a very nice sounding cam and does work well in a lo po engine on the street way better than the lunati 292/292 worked in the stock sb 360 it runs circles around it ![](/ubbthreads/images/graemlins/drive.gif) I am sure there are others that work just as good if you campair the #s me picking them out of a hat,hands down its been the best one in my stock junk ![](/ubbthreads/images/graemlins/shruggy.gif)
Re: Cam Question
[Re: Twostick]
#851177
11/17/10 09:17 AM
11/17/10 09:17 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Kevin
no idea motor came in the car. 484 and 509 are good cams, but they like compression, head flow, gear and converter. I wouldn't use either in anything less than 10:1, 3000 stall and 3.91's.
Re: Cam Question
[Re: goldmember]
#851179
11/18/10 03:12 PM
11/18/10 03:12 PM
Posts: 4,799 ILL
MLR426
ILL
my
Gold Member, Send your signature picture over about 5:30 tonight I need to take her out for a what a lady ![](/ubbthreads/images/graemlins/drool5.gif)
logan426
Re: Cam Question
[Re: Triggerfish]
#851182
11/19/10 10:13 AM
11/19/10 10:13 AM
Mr.Yuck
Brookeville, Md
No intention to steal this thread, but I changed out the 284/484 MP cam in my newly built 451 low deck w/ 440 source kit & eddy heads, for an Engle AMC grind K56/K58 cam w/ 112 lobe separation. I wonder from reading this, if I made the right choice.
so if I'm reading their website right that would be 504/514 and 224/230 @.050??? should run good. What is the stall and gear? I'd think you'd need less stall w/ that cam than the 484 and you'd want at least 3.55's, 3.91's would work better.
Re: Cam Question
[Re: Mr.Yuck]
#851183
11/20/10 12:22 AM
11/20/10 12:22 AM
Twostick
Still wishing...
Still wishing...
Kevin
I would be willing to bet the guy that installed it just did a "dot to dot" on it and it wasn't even close. Too bad you didn't check the dial on it before you changed it. You might have been impressed.
Kind of an apples to rutabagas comparison but I run the .509 in my 8.97:1 493 in a 4800 lb. 66 New Yorker. It's the 108 LSA installed straight up. It made over 500 ft/lb from 2000 to 5500 and peaked 600 ft/lb @ 4000. Idling at 1100 was a pain with the stock converter but I had no problem breaking a motor mount in the driveway seeing how much all that torque would increase stock stall speed by. I ran a 2800 Turbo Action converter after that and it drives around town just fine. The only time I took it to the track, it went a no traction 13.92 at 101 thru full exhaust with a 2.76 SG on regular gas. Considering the difference in cubes I would say the 484 would have the same street manners in a basic 440.
Kevin
Re: Cam Question
[Re: indytex96]
#851185
11/22/10 03:45 PM
11/22/10 03:45 PM
Posts: 4,799 ILL
MLR426
ILL
So what kind of gains am I looking at by advancing 4 degrees? Just curious if it is worth purchasing a new gear set as I already have a new std one. Thanks again!
Anyone?
It is worth the price of new chain. Advancing the cam 4 degrees gives great low end torque.
logan426
