Re: Whats easier? BB or SB swap into /6 72 Dart
[Re: SPWC]
#85055
07/07/08 12:32 AM
07/07/08 12:32 AM
Posts: 1,233 Eastern North Carolina
cyphre666
I would have to say, the 360 will be an easier fit. Although a BB Dart is always nice to putt around in. ![](/ubbthreads/images/graemlins/drive.gif) Small block ![](/ubbthreads/images/graemlins/wrench.gif) Big Block ![](/ubbthreads/images/graemlins/sawzall-smiley.gif)
[Re: SPWC]
#85057
07/07/08 12:53 AM
07/07/08 12:53 AM
Go with the 400. It's an easy bolt-in swap with Schumacher mounts. Low deck BB's fit pretty well.
[Re: RobX4406]
#85059
07/07/08 08:54 AM
07/07/08 08:54 AM
Posts: 75,128 A Banana Republic near you.
JohnRR
you likely won't be using the column shifter stuff with a BB. Might get away with it with a SB.
not with a 727 , the Z bar for the shift linkage is very hard to find
#85060
07/07/08 09:52 AM
07/07/08 09:52 AM
Posts: 1,629 OH
Red383
OH
[Re: SPWC]
#85067
07/07/08 11:44 AM
07/07/08 11:44 AM
Posts: 18,686 Fresno, CA
Jim_Lusk
Fresno, CA
Like I said,im just kicking the idea around. Sorta like pipe dreamin". Figured the sb would be easier,since A bodies were optioned with them . Thanks for all the perspectives on the subject.
They were optioned with big blocks, too.
[Re: Jim_Lusk]
#85068
07/07/08 12:24 PM
07/07/08 12:24 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
A 68 340 4spd dart was just as fast (or faster by some acounts) as a 383 dart, 440 wasn't much better.
Headers did tend to level the playing field but they are a nightmare to install and work around on a BB a-body, and the weight still hinders handling and drag race hook up.
[Re: Jim_Lusk]
#85072
07/07/08 02:11 PM
07/07/08 02:11 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
not after 69 ![](/ubbthreads/images/graemlins/Twocents.gif)
