Re: low deck vs RB stroker
[Re: dragram440]
#850670
11/11/10 01:07 PM
11/11/10 01:07 PM
Posts: 4,219 New York
polyspheric
New York
The better forgings are better than the factory forgings, and better than all factory castings (400). A 383 forging is pretty stout, depends on your power level.
Downside to low deck: Smaller case volume makes it more sensitive to pressure changes, blow-by etc. if stroked Can't get the same rod ratio choices.
Boffin Emeritus
[Re: polyspheric]
#850671
11/11/10 01:49 PM
11/11/10 01:49 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I guess you could say I have both I have the Indy Maxx aluminum block,it is a RB with the deck height cut down to 9.965 B block. The crank,dist. and everything else is the 440 RB stuff. I have been told a 4.25 crank is the biggest you can put in a low deck (B)block. After reading this post I am not so sure about mine,the block should take a 4.50 crank same as any other RB. But what I am not so sure about is finding Rods & Pistons to match.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Twin Turbo Mower]
#850673
11/11/10 06:37 PM
11/11/10 06:37 PM
MRMOPAR622
Sweet Home Alabama
Twin Turbo Mower What's lenght of the rods & what's the compression height on the pistons?Thanks
[Re: AndyF]
#850676
11/11/10 09:02 PM
11/11/10 09:02 PM
Posts: 16,941 NC
440Jim
NC
You can also put a longer rod into the RB and the crankshaft is a little stronger.
Andy, Why is the RB crank stronger? For the same stroke, the low deck will have less journal overlap making it stronger (2.750 vs 2.625" mains).
I have my low deck blocks align bored for 440 bearings and aluminum main caps. This gives the better 440 bearing choices, and cushions the factory block somewhat. And my 4.250" stroke (nice) has 2.200 rod journals to help overlap vs the MOPAR 2.375"
[Re: 440Jim]
#850677
11/11/10 11:19 PM
11/11/10 11:19 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i don't believe the journal overlap amounts to anything when being built in a stock block. any decent crankshaft will be stronger than the block it's being installed in. the comment about the 470 B being equivilent to the 493 RB is, well, not correct IMO. it always falls back to how you build them and you wouldn't build both of those combo's with the same parts, so how can you even compare them like that? "usually" the B400 will have stronger main webbing than a RB and that's the only real advantage. bore size isn't really a factor since most factory blocks have so much core shift. i like the RB bearing choices better than the B motor as well as the intake choices. pushrod weight is a total non factor since stronger, heavier pushrods will be used in anything making any real power. the weight on that side of the rocker is almost meaningless anyeway, IMO. the pushrod angles are better with the RB, especially if offet rockers or offset lifters are used. either engine choice will make enough power to break the block and typically they're within 75-100 horsepower in that regard, but there's no guarantee that either block will safely make X amount of horsepower.
machine shop owner and engine builder
[Re: Performance Only]
#850678
11/12/10 12:25 AM
11/12/10 12:25 AM
Posts: 9,945 Weddington, N.C.
Streetwize
Weddington, N.C.
Dan I guess we'll agree to disagree but from my experience (and like you I was building strokers out of 383's, 400's and 440's long before they were mainstream) the combination of the smaller bearing area and lighter bobweight (again from my expereince only) a 470 is more than enough to offset a roughly 5% displacement handicap to the 493 if those motors have the same machine work, compression, heads, cams, induction and exhaust. A bit lower piston speed means less frictional losses at any given RPM as well. Don't get me wrong, nothing at all wrong with a 493 it's just that from my builds the extra "coke can" or so of total displacement only brings it about even...again all else being equal. I also feel confident backing that up because you can (well, I can) definately feel the difference between a comparable 2.200 journal 511 and a 493, again it's I feel it's the smaller internals. There was a reason Bill Jenkins ran 2.00" rod journals and not the 2.100"s all those years ago. And don't guys still swear a comparable 327 will walk the dog on the same spec 350 chevy? Now NASCAR runs 1.89's, less surface area/rotating friction with still sufficient strength I suppose. It's interesting, in my day job I'm working on a huge 65.5 Megawatt Hydro turbine generator and I'm working with some very clever engineers who I'm learning a lot about the criticality of bearing temperatures and pressures. The stator is roughly 30' in diameter Lets take a 'real world' example (not an all-out race motor) of a street-strip 10.5:1 E-headed motor with an MP 557 cam, both have a 950HP and an RPM or a street dominator or an M1 (you pick) and 2" x 3 1/2" headers with a 3500 stall 10" t/A and 3.91 gears in a 67 coronet. I'd lay money down that they'ed run virtually a dead heat in the quarter, round after round. if there was a difference it would be that the 470 would peak a few 100 RPM higher, put a 4.10 in the 470 and it would be even quicker. What I've outlined here is the basic bullet-proof reliable 11.70 & high 1-teen street strip combo, I've done it with both motor combos...but with ported iron heads. Of course these days everybody seems to build 511's so I suppose the old school 470's are out of favor...but back inthe day they were the hot "stealth" ticket Heck it's easy to go 11's with just a basic E-head 440 these days. If you asked "why would you build them the same?", I would have to ask you (respectfully) why couldn't (or for this example relating to heavy street/week-end strip use which is what most people on here build for) wouldn't you build them essentially the same? It's a 'fun' motor either one. but going back to the original post, I wouldn't EVER feel like I had to defend running an RB and in his case...I'd just smile and say "Because it's the one I had!"
[Re: polyspheric]
#850679
11/12/10 10:09 AM
11/12/10 10:09 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Ya, and it matters how???
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#2937039
06/26/21 03:25 PM
06/26/21 03:25 PM
Posts: 16,166 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
It is worth digging up this over a decade old thread IMO. Lot's of good info and the link from 440source is VERY educational. I learned a lot about big blocks. Only thing I didn't see in the article was any info on RV blocks and whether they are any different so I guess they are not.
Facts are stubborn things.
[Re: Von]
#2937047
06/26/21 03:56 PM
06/26/21 03:56 PM
polyspheric
New York
Let me guess: rod ratios don't matter?
Boffin Emeritus
[Re: 440Jim]
#2937048
06/26/21 03:58 PM
06/26/21 03:58 PM
polyspheric
New York
Backward
Boffin Emeritus
[Re: polyspheric]
#2937068
06/26/21 04:51 PM
06/26/21 04:51 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Polyspheric,
Can you post some time slips or dyno sheets from testing that you have performed and explain what impact (positive or negative) the rod ratio had?
[Re: GTS340]
#2937104
06/26/21 07:45 PM
06/26/21 07:45 PM
polyspheric
New York
How do you think OEM ratios are chosen (if they anything but "what do we have on the shelf)?
Boffin Emeritus
[Re: polyspheric]
#2937120
06/26/21 08:58 PM
06/26/21 08:58 PM
GTS340
Romulus, MI
How do you think OEM ratios are chosen (if they anything but "what do we have on the shelf)? Probably chosen with the thought of a long service life in mind and not so much on maximizing horsepower. So safe to assume you haven't done any first hand testing on rod ratios?
[Re: rebel]
#2937132
06/26/21 09:24 PM
06/26/21 09:24 PM
Posts: 43,913 Bend,OR USA
Cab_Burge
My old 400 block bracket motor is stroke to 4.300 with 6.700 BB Chevy type h beam rods(518 C.I. The current motor is stroked to 4.250 with 4.360 bore size I race it on E85 and have rana best 8.862 ET at 150.++ MPH in the 1/4 mile. Best 1/8 mile has been 5.50 ET at 125.++ MPH weighing 2850 Lbs. No fill in either block ever
