Re: True Street car ET's
[Re: 383man]
#849794
11/15/10 03:08 PM
11/15/10 03:08 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I have to wonder how many of these "street cars" that are running 10's and low 11's are running a nitrous kit to get there? I have the feeling there are at least a few guys here that have outlined their combo, and conveniently left out the 150-shot plate kit. I know Turbo seems to be the best way to go crazy fast and stay streetable, but lets stay within the budget of the average street / strip guy. Of the guys driving to and from the track, and getting deeper than 11.90, who can claim 100% N.A.? We know the Red 63 is on the list..... Who else?
[Re: StealthWedge67]
#849798
11/15/10 04:01 PM
11/15/10 04:01 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
My Duster had no power adders of any kind.
#849799
11/15/10 04:23 PM
11/15/10 04:23 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
My mid 9s are on motor only, and on pump premium from Sparky's fireworks. I have driven it to the track, but normally trailer it.
[Re: justinp61]
#849802
11/15/10 06:16 PM
11/15/10 06:16 PM
Posts: 1,056 Mt.Vernon IL
Twin Turbo Mower
Mt.Vernon IL
Drove it to work tonight. 6pm to 6am. 4 1/2 hours to go.
Were you at I-57 last Sunday? If it was your car there, it's awsome, when it came idling my pit it was so quiet. Then i saw it run low 6's , I about fell off the trailer. Honestly I thought you were spraying it. Does it have a 8 3/4 in it? I couldn't tell. from where I was standing. I'd put a bar in it too, but thats just me. Very cool fast car .
I drive mine to work, cruzin and have driven it to get groceries on a couple of occasions. It's been mini tubbed, has the frame tied and has a roll bar. I hated to put the bar in it but the thought something happening at the track (1/8) at 104-106 mph without one didn't appeal to me. It has Kirkey seats, at the time I couldn't find a decent set of factory low backs. The ones I found were $400 and meeded recovered, the covers were another $400. It also has a glass hood and front bumper. It has full interior, factory gauges, factory glass, good heater, wipers work well, the map, glove box and trunk lights all work.
It runs high 6.50s in the 1/8 with 1.38 60's on street radials without the exhaust on it. It's powered by a pump gas 408, a 9.5" converter in a 727 with a 4.10 geared Dana and weighs 3260#.
I'm probably disqualified from being a "street car" (at least thats what one of the local gm guys said) because I don't have a horn. I had to remove them to install a puke bottle. If I ever find a beep beep horn I'll find a place to put it.
Yup that was me. There was a lot of mopars there that day more then I have seen at I-57 in a while. I did put a roll bar in it. I did not want to but safety first. It does have a 8 3/4 with 35 spline axles and a spool. I looked but could not find a locker for 35 splines. Stock wheel wells just has offset hangers, cal-tracs with mono leafs afco double adjustable shocks in back. I have a tci streetfighter converter 10 inch rated 3500 but flashes to 5k, still tight for street driving to suit me. Its all steel bumpers hood ect. No bottle here just lots of cubes.
Low deck indy aluminum block. 4.5 bore 4.375 stroke 6.535 rod. Diamond dished pistons 16.5 cc. 440-1 heads cnc ported by modern cylinder head 350cc runners 75 cc chambers for 12.2 to 1 compression. Harland sharp 1.6 ration rockers. Isky red zone lifters. Bullet cam 264/274 @ 050 690/690 lift. Tti 2 inch headers gona buy the step headers 2 1/8 some time. Magnaflow mufflers.
#849803
11/15/10 06:37 PM
11/15/10 06:37 PM
Posts: 4,247 Newfoundland
codfish
Newfoundland
I have to wonder how many of these "street cars" that are running 10's and low 11's are running a nitrous kit to get there? .... Of the guys driving to and from the track, and getting deeper than 11.90, who can claim 100% N.A.? We know the Red 63 is on the list..... Who else?
MILD 540 lift cam with a fair amount of duration. 11-1 compression. 3800 convertor. FULL interior. ALL steel body. 3.73 gears and drag radials. And NO race fuel. Strictly 91 octane. Can't even buy 93 here .
codfish
#849804
11/15/10 06:44 PM
11/15/10 06:44 PM
Posts: 518 ny
greenmcode
ny
Thats pretty flippin' fast for such a mild combo. Any nitrous involved here? Please tell us more about the combo Carb & intake? exhaust? compression? Cam specs?
No power adders NATURALLY ASPEEERATEEED.. Stock holly carbs with pro max plates.. Stock alum intake.. stock exhaust manifolds with 2 1/2 tti x pipe dynomax mufflers.. 11.75 compression Hyd flat tappet cam.[no specs] Car is very quiet and drive anywhere [110/93 mix] 11" converter from ultimate 2600. 3940lbs
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
[Re: greenmcode]
#849805
11/15/10 09:01 PM
11/15/10 09:01 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
Mine is NA and has an 8" Converter and a big nasty roller cam. Its also slower than it should be LOL but I am lining that out. (11.70s)
I think streetable is a matter of opinion or tollerance. Mine is loud, rattles, has no heat or AC and I love it. Sure it would be nice to have overdrive and AC but I have played that game with a mustang. While I miss the comforts of the stang sometimes its just not the same as old school muscle.
68 Barracuda Formula S 340
#849806
11/15/10 09:11 PM
11/15/10 09:11 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Really? Maybe you ment 10.90s, or even 10.40s
#849807
11/15/10 10:56 PM
11/15/10 10:56 PM
Posts: 2,679 owt west
Thread Ender1
owt west
Ill bite, 410ci SB 10.7 to 1 comp... 10:85 at 122 thru the muffs on DOT radials, and theres more left on the table.
#849808
11/15/10 11:05 PM
11/15/10 11:05 PM
Posts: 2,503 Illinois
CRE2004
super gas
super gas
Illinois
I have to wonder how many of these "street cars" that are running 10's and low 11's are running a nitrous kit to get there? Of the guys driving to and from the track, and getting deeper than 11.90, who can claim 100% N.A.? We know the Red 63 is on the list..... Who else?
10.63 at 130mph NA 3.73 rear gear, 3800 stall converter, drive anywhere
[Re: TheOtherDodge]
#849811
11/15/10 11:22 PM
11/15/10 11:22 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
It really doesn't matter what you do to get your et's...
What is more interesting is to hear the cam/converter/gear sizes and how loud the vehicles are...
IMO, a real street car would have a little hydrualic roller in the .228 duration range, no more than 3500 stall, around a 3.54 gear with a 30" tire and be super quiet like a factory cadillac and still run 9's!
Oh wait, that sure does sound like mine!
Not NA with that cam. Ron
