Re: Why did I bend a pushrod? [Re: ] #849303
11/10/10 02:46 PM
11/10/10 02:46 PM
SoCal
Brian Hafliger Offline
SoCal
Hard to beat Crower lifters marsh performance aka Moparts Connection-- board sponsor has them in stock--The Comps are JUNK
He's running my lifters, and they are far from junk.
Solid roller cams are very unforgiving and it can be the spring, lash or pushrod that will likely be the FIRST thing to rear it's ugly head.
Already talked with Galen and I'm fairly certain it's not the lifter that caused the problem. Instead of pointing fingers we talked and went over everything...GOOD CUSTOMER!!
I agree the pushrods should be .120 wall 3/8 or .085 wall 7/16 IMO but that's not what caused this to happen.
Might be time to change the lobes for more "street" driving this time around.
Brian
Brian Hafliger
Re: Why did I bend a pushrod? [Re: polyspheric] #849304
11/10/10 02:55 PM
11/10/10 02:55 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
So what "caused" the lifter to fail?
I'm no engine builder however,
My theory is the push rod was flexing and pole vaulting the valve train causing the lifter to seperate from the camshaft. Possibly flat spotting the roller needles and or fracturing them when the roller was reintroduced to the camshaft leading to the destruction.
It would be interesting to see what the roller needles look like on the other 15 lifters.
Sorry about your broken toy Galen
Re: Why did I bend a pushrod? [Re: Brian Hafliger] #849305
11/10/10 03:00 PM
11/10/10 03:00 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The question then becomes was it a lifter failure due to lack of lubrication at low speeds? I do not think a 230# seat pressure spring, is putting that much of a DIFFERENCE in load on his set up going from 6800 to 7200 just ONCE.I have many many BBM engines running .083 and .095 pushrods in bracket race engines with never a failure. Is the stiffer pushrod better? 100% yes. Is this what caused Galens breakage? I hardly doubt it.
Does he really have that aggressive of a lobe in that engine where it was surging or bouncing to the point of failure? ( I dont know his cam, apparently you do, so asking is it that aggressive?)
Again, its not a radical piece, and the RPM was not out of range for a 230/650ish spring.
You know and I know thta lifters just simply dont " fail". ( I am NOT bashing the lifters here, has nothing to do with the " brand" here in my opinion) It would have to have been surging for a long time to beat the needles out of it.
Just my , send me a PM if you want instead of here. Not sure if its " all on the table" here. Thanks.
And yes, Galens a good dude.
RIP Monte Smith
Re: Why did I bend a pushrod? [Re: CompWedgeEngines] #849306
11/10/10 04:32 PM
11/10/10 04:32 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Thanks for the help guys. I am going to send the lifters to Brian so he can take a look at them. The cam I am running is a comp RX296 R8. 263/270 at .050. Lift is .650/.651 with 1.5s. I am running a 1.6 Harland sharp and a 943-16 spring. I had to go with a plus ..050 retainer to get my spring height. I aired on the side of clearance and set the installed height at .950. In doing so my spring pressure may be lower than I expected. I am going to check all spring heights and pressure and will report my findings. I have to figure this is an error on my part. I am thinking a few little ones that added up to my failure. My main objective is to find out why and prevent it next year. I will keep you all posted and run the game plan by you on the repair. No hole in the world block, no broken head, thankfull for that. I went from brad Penn to Royal purple, that may have been a mistake also. Going to look at some bearings. I have pics but I have to get my kids over to help me get them off this stupid camera. It's still good to be a mopar guy
Re: Why did I bend a pushrod? [Re: galen] #849307
11/10/10 05:38 PM
11/10/10 05:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Can't rule out pushrod flex as a contributor, but even good roller tappets can't take any air gaps - the needles just snap and escape, the roller wheel collapses onto the axle, blah.
Even though this may not be a quality problem at all, you must examine the other 15.
The Harley-Davidson roller test (since they all have them since 1929) is:
1. does it rotate freely, no scratchy spots or drag
2. end-play is the same on all tappets
3. zero up-&-down play
Boffin Emeritus
Re: Why did I bend a pushrod? [Re: galen] #849308
11/10/10 05:56 PM
11/10/10 05:56 PM
NC
440Jim Offline
440Jim  Offline
NC
I agree, check the springs. Not enough spring pressure can cause the lifters to get beat up, especially as the rpm goes above 6500 etc. Besides the installed height, the street driving (how many years?) may have caused the springs to lose tension.
I don't know for sure, but some might say 275/675 pressures and 0.120" pushrods would be the preferred setup. But don't expect the lifters to last forever.
Re: Why did I bend a pushrod? [Re: 440Jim] #849309
11/10/10 10:38 PM
11/10/10 10:38 PM
SoCal
SoCal
Definitely need to check springs I.H. and check again for pressure. When hot they lose approx. 20lbs. on the seat so if they were close to 200 cold then that is biggest problem but not sure that's what the springs are so we have to wait.
Pushrods probably didn't help anything and if the springs were weak allowing valve bounce this would be amplified by the thin wall pushrods.
Galen, did you go to a thinner oil when you switched to Royal Purple? Thinner oils allow more spring temp too.
Brian
Brian Hafliger
Re: Why did I bend a pushrod? [Re: Brian Hafliger] #849310
11/11/10 01:25 AM
11/11/10 01:25 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I suspect (no actual data) that thinner oil may have lower surface tension, and form smaller droplets in the cover, get around better, and cover more area before draining.
I'm surprise that I haven't seen more remarks about something already in use elsewhere: a lower spring cup on the spring OD, normally used to prevent chafe and locate the spring (rather than a seat on the guide OD) with a taller lip than normal. The cup retains some oil, and when the spring is really moving, it acts like a bird in a birdbath - it splashes the oil out of the cup very nicely.
Boffin Emeritus
Re: Why did I bend a pushrod? [Re: polyspheric] #849311
11/11/10 02:22 AM
11/11/10 02:22 AM
SoCal
SoCal
I guess I should state that what I mean is super thin oils like 5 or 10wt don't seem to cool as well as 30wt. I don't have any data myself but I've been told this by and oil rep. I guess that doesn't mean it's correct?
Anybody have any real data on oil viscosity's affect on cooling????
Brian
Brian Hafliger
Re: Why did I bend a pushrod? [Re: Brian Hafliger] #849312
11/11/10 12:51 PM
11/11/10 12:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
AFAIK the most important factors in using oil to transfer heat are:
1. volume
2. motion (is it passive, or does it drain away constantly)
3. area (how large a heated surface is washed)
Oil from the rockers etc. that can "find" a narrow deep channel to the drains is going to do less than oil that must pass over the exhaust guide bosses, exhaust port rooves, and spring bases first. Examine your head's upper surface - sometimes there are obvious areas where a simple piece of sheet metal creates a longer path.
Some engines have drains adjacent to hot spots - here, drilling the drain slightly oversize 1/4" deep and inserting a thin tube 3/8" tall (old conduit, etc.) makes the oil pool out and cover the hot area 1/8" deep before reaching the drain opening. This is even possible with some pushrod holes. Remember to analyze this as the engine sits in the chassis, both as to front/rear and left/right.
Boffin Emeritus
Re: Why did I bend a pushrod? [Re: polyspheric] #849313
11/11/10 08:52 PM
11/11/10 08:52 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Galen,do you ever blow the tires off hard in 1st and then click 2nd gear ??That creates HAVIC in the valve train Don't ask how I know Here is a picture of your lifter
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
