'splain to me why #848474
11/07/10 10:29 PM
11/07/10 10:29 PM
South Jersey, NJ
DragDart360 Offline OP
South Jersey, NJ
Every time I tow my car the tie downs are loose when I arrive at my destination. I have axle straps at rear and loops welded to the K frame in front. I tighten all straps with car in neutral then put it in park for travel. I have Summit tie down straps.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: 'splain to me why [Re: DragDart360] #848475
11/07/10 10:33 PM
11/07/10 10:33 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
How are you looping the axle straps?
Maybe they're slipping on the tubes and cuasing things to slack off.
Re: 'splain to me why [Re: WILD BILL] #848476
11/07/10 10:35 PM
11/07/10 10:35 PM
Q
Quicktree Offline
Quicktree  Offline
Q
the car is probably moving around on the trailer
Re: 'splain to me why [Re: DragDart360] #848477
11/07/10 10:43 PM
11/07/10 10:43 PM
Cab_Burge Online work
Cab_Burge  Online Work
The straps will stretch once they have a load put agianst them, try driving it 4 to 15 miles and retighten them, really honk down on them both times What weight are your straps and tie downs rated at? I use four 5,000 lb rachet strap tie downs and the four 5,000 tie down straps, two straps wrap around the rear end housing, one on each ladder bar bracket and two in the front wrapped around the K member they will loosen up, the longer I drive it before checking, (sometimes I forget to check ) the looser it will be Once I retighten them they seem to say tight until I get to where I'm going
Re: 'splain to me why [Re: Cab_Burge] #848478
11/07/10 11:14 PM
11/07/10 11:14 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I've found that if you pull the straps really tight before you ratchet you don't get enough strap rolled around the ratchet center bar they will back off easily, better to have a roll of strap on the roller, they hold better, mine used to loosen and I finally figured out I just wasn't getting enough strap rapped around the roller, think it was causing the strap to slip just a little.
Re: 'splain to me why [Re: wyoming] #848479
11/09/10 10:08 AM
11/09/10 10:08 AM
Lehigh Acres, Florida
rickstershemi Offline
Might be the strap itself, not sure what brand your using, but I have never had that issue, I use heavy duty 2 1/2" straps I picked up at Northern
Also make sure you ratchet them with the car in neutral
Rickster
Re: 'splain to me why [Re: rickstershemi] #848480
11/09/10 11:08 AM
11/09/10 11:08 AM
PA
moparacer Offline
moparacer  Offline
PA
I tow with an enclosed trailer and I have a block of wood cut to slide under the K frame up front. I ratchet it down on the block so it doesn't bounce while towing. My car has adjustable shocks on back and I set them full stiff when we ratchet the back down.
Never had the car come loose towing 80 mph at times. You have to keep it from bouncing thats how they get loose.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 'splain to me why [Re: wyoming] #848481
11/09/10 08:01 PM
11/09/10 08:01 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Re: 'splain to me why [Re: The Shadow] #848482
11/09/10 08:19 PM
11/09/10 08:19 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Yes the straps have to have at least one wrap around the ratchet pin before tightening also tie suspension down not the body
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: 'splain to me why [Re: DragDart360] #848483
11/09/10 09:14 PM
11/09/10 09:14 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
How are you connecting the straps? I always cross the two straps on the back of the car (an "X" pattern), ratchet then snug, then tighten the car in place with the front straps pulling straight forward. Also, Make sure the car is in neutral when tightening the straps. I don't like to two in "park" but some do. I feel if you tow in park, you could damage the transmission with the car rocking against the parking pawl. Never tighten the car in place while in "park".
Scott
Re: 'splain to me why [Re: 65dragnet] #848484
11/09/10 09:36 PM
11/09/10 09:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I even find that when I tow my quads on top of my snowmobile trailer if I don't get a little bit of wrap around the ratchet mechanisim before snugging it down, they will work themselves a little loose. Found the same thing on the car hauler I borrowed a couple times as well.
Re: 'splain to me why [Re: DragDart360] #848485
11/09/10 10:33 PM
11/09/10 10:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Those blue Summit straps are cheap and stretch. I had mine rewebbed and the stretching stopped. I towed 17K miles this past summer and my Kinedyne straps didn't stretch.
IMO Never cross your straps, keep em on each corner.
That way if one strap breaks the other one isn't trying to pull your car off the trailer.
Here's my summit straps rewebbed with Kinedyne material. There is a difference, I'm here to tell you. I used these for 12K miles so far.
Re: 'splain to me why [Re: DaytonaTurbo] #848486
11/09/10 10:42 PM
11/09/10 10:42 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I just completed another 1200 mile trip hauling my 64 bonneville from the gulf coast back to Michigan, the straps were just as tight as when I left. I use 4 straps, all straight front to back. I have never had a strap come loose, knock on wood, but I have at least three raps around the center mechanisim. Thats what does the holding, the binding of the strap on top of the next one. Also make sure the handle is locked down, not half way up. I really don't crank them down either , just tight on the rear end and the front lower control arm, just let the body bounce.
Re: 'splain to me why [Re: Challenger 1] #848487
11/09/10 11:04 PM
11/09/10 11:04 PM
South Jersey, NJ
South Jersey, NJ
OK I follow all the golden rules. I think it's the cheap straps stretching. I'll have new quality straps before next season.
Thanks for all the informative replys
Re: 'splain to me why [Re: DragDart360] #848488
11/10/10 10:43 AM
11/10/10 10:43 AM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
I use chains and binders no problems in 20 years.
Re: 'splain to me why [Re: DaytonaTurbo] #848489
11/10/10 10:47 AM
11/10/10 10:47 AM
an8sec70cuda Offline
Gotta have it wrapped around a couple times or they will loosen up.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 'splain to me why [Re: DragDart360] #848490
11/10/10 03:08 PM
11/10/10 03:08 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Is your car getting any longer?
Re: 'splain to me why [Re: Challenger 1] #848491
11/12/10 03:20 PM
11/12/10 03:20 PM
ProStDodge Offline
ProStDodge  Offline
If you don't cross at least one pair of straps, the car can move side-to-side while strapped down. Yes, I have seen it happen, enough to move the vinyl floor tiles out of position.
Scott
Re: 'splain to me why [Re: ProStDodge] #848492
11/12/10 10:48 PM
11/12/10 10:48 PM
Cincinnati, Ohio
Cincinnati, Ohio
Scott
First off, Don't you think the cheap floor tiles have anything to do with it??
What happens if one of those crossed straps comes loose? Seems like it would pull the car sideways.
I have trailer ed my car on a open steel deck trailer now for over 35K miles in the last 3 summers and it never moves on the trailer. Even without straps tight, Parking brake is always on and in PARK. 17K miles this year.
Iowa, got to get some sleep. This night we chased the sunset for over a hour, amazing
Bonneville salt...
Utah rest area, the nicest I've seen.
Key West Fla, nice!! 90 miles from Cuba!
BTW I have pulled a 49' trailer over 100K miles and this small open trailer has been way cooler and a lot more fun than the huge enclosed. I can get the open trailer in most campgrounds. No more people asking on the CB, what's in the trailer? Just cool thumbs up by most people we see.
Re: 'splain to me why [Re: ProStDodge] #848493
11/12/10 11:02 PM
11/12/10 11:02 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Scott
It's the law here to have your straps crossed when towing
I would imagine some states would also have the same laws
