Re: Engine build advice
[Re: 68CoronetRT]
#848341
11/24/10 06:35 PM
11/24/10 06:35 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
That may be smaller than a stock HP cam? You'll get a dead smooth idle out of that.
[Re: ahy]
#848343
11/25/10 05:46 AM
11/25/10 05:46 AM
Posts: 5,163 CT
GTX MATT
CT
I noticed this kit on summit a few days ago I had never seen before. Not really sure about the pistons, they seem to have a quench pad on one side and a good sized relief on the other side, and the compression height seems like it would build decent compression for a street engine. I figured I'd post the link up and see what other members thought about them because I wanted some opinions on them myself. 800 seems like a good price to me for a kit with forged pistons, they may be heavier and may not be the best, but they seem good for a budget build. http://www.summitracing.com/parts/FEM-CSMHP816-300/?rtype=10
[Re: GTX MATT]
#848348
11/26/10 10:17 AM
11/26/10 10:17 AM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
The L-2295F is a bit of an odd carrot for what is deemed a practical pump gas build today. No quench with the 2.03" CH, but puts the CR on the sunny side of 10.0:1.
If you put 92 cc heads on it, fat enough gasket, minimal or no deck cutting and the right cam, I'm sure you could make it work.
[Re: ahy]
#848352
11/26/10 02:03 PM
11/26/10 02:03 PM
Posts: 1,200 UK
602heavy
UK
Hoe about this one........... Lunati Voodoo 262/268. advertised 220/226 @ .050" 112 lobe sep/108 icl. 41 degrees O/L @ seat to seat. Those voodoo cams are possibly the best off the shelf grinds out there in my opinion , or should we say those Harold Brookshire cams..... Summit part # 60302.
