Re: Fiberglass experts, help with hood [Re: 440Satellite] #847810
11/08/10 08:35 AM
11/08/10 08:35 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I am NOT a fan of the zdus at all. They are famous for popping up(if not mounted perfectly) ...and then you can lose the part.
YES on the filling. ALSO ...with the metal tubing ....that offers a TON more stiffness. The foam offers NOTHING but a form for the fiberglass mat bracing. THIS is OK .. but if you are going through all this ...do-it with metal. WELDING IT would be better but not really required.
I have done the metal bracing MANY times in regular production. The trickest ? ....magnesium tube.
Re: Fiberglass experts, help with hood [Re: dOc !] #847811
11/08/10 09:07 AM
11/08/10 09:07 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I bought a flat hood from AAR and had to cut a hole in it for the dual quads. I called AAR since I would have been cutting thru the bracing/structure. They instructed me to buy a celotex styrofoam insulation sheet. Following their instructions I cut some strips and placed them on the underside of the hood. I completly glassed them over and all was good. The hood was structurally sound and my carbs and air cleaners were poking thru. (Added a scoop later)
Keep old mopars alive.
Re: Fiberglass experts, help with hood [Re: 2boltmain] #847812
11/08/10 09:24 AM
11/08/10 09:24 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
AGAIN I say ...
...and the same goes for that styrofoam sheet.
Re: Fiberglass experts, help with hood [Re: dOc !] #847813
11/08/10 06:45 PM
11/08/10 06:45 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
AGAIN I say ...
, but then thats all it's supposed to offer, the increase/added stiffness is not the foam itself, its the increase in the depth of the cross section ( it could almost even be just air , except that is hard to form)that one is trying achieve. Steel ubing mightwork well and easy, but hard to imagine it outperforms foam lb for lb.
Re: Fiberglass experts, help with hood [Re: jcc] #847814
11/08/10 07:50 PM
11/08/10 07:50 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
I was told the foam is just the form/mold and that the cured fiberglass is the where the strength lies.
Re: Fiberglass experts, help with hood [Re: 2boltmain] #847815
11/08/10 11:38 PM
11/08/10 11:38 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Most definately.
Y'know, with what you're starting with and the end result you want and the time and effort its going to take to get you there, you'd be WAY better off just buying a new hood. Even the less expensive lower end units will be far better than what you're likely to end up with. F'glass is not the most enjoyable stuff to play with.
Re: Fiberglass experts, help with hood [Re: Stanton] #847816
11/09/10 08:33 AM
11/09/10 08:33 AM
Hazlet, NJ
440Satellite Offline OP
super gas
super gas
Hazlet, NJ
I dont agree, its really not a bad hood as it sits, I'd have no problem using it as is, once all the zdus btackets are in place it would sit nice and straight. I just want to beef it up a bit to make it stronger and as far as the corners go, if there easy enough to fix, I'll fix em, if not its no big deal.
For some of us, working on our projects is the best part of having one. I enjoy working on them even more then driving them, I'm usually looking for something to work on or modify.So somthing like this I look foward to.
Butch
1972 Duster 318 4 speed 1958 392 Hemi engine waiting to be built!!!!!
Re: Fiberglass experts, help with hood [Re: 2boltmain] #847817
11/09/10 11:17 PM
11/09/10 11:17 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Very true ....foam offers ZIP in strength ....BUT IF you put some mag, alum or lite-weight steel tubing in there ... the hood is almost as stiff as a steel hood.
I have done this on at least a 100 hoods.
Re: Fiberglass experts, help with hood [Re: dOc !] #847818
11/10/10 01:29 AM
11/10/10 01:29 AM
dulcich Offline
dulcich  Offline
Don't question the Doc. Well at least not on Fiberglass. He is offering a very sensible and practical fix. Sure you can stiffen it with a top-hat of glass on a core of anything, but the conduit is easy to work with and will add additional stiffness.
-dulcich
Re: Fiberglass experts, help with hood [Re: dulcich] #847819
11/10/10 02:01 PM
11/10/10 02:01 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
-dulcich
Why THX d-guy ..... but shouldn't you add in-there NOT questioning me OR you about the superiority of the Plastic-Fantastic ....aka ThermoQuad ?
SHOULD we sign-you-up as part of the ThermoSquad?
Re: Fiberglass experts, help with hood [Re: dOc !] #847820
11/10/10 09:39 PM
11/10/10 09:39 PM
Hazlet, NJ
super gas
super gas
Hazlet, NJ
Hey Doc, any tips on adding material to the edge, as is the case in my corners. Should I just use a flat surface butted up to the topside of the hood and overlay a few layers of mat from the underside to build it up?
Gonna build my wood stand tomorrow fitted to the stock hood so I can lay the fiberglass hood down and start working on it.
Butch
