Correct Fender bolts, studs and nuts for T/A #847477
11/06/10 05:42 PM
11/06/10 05:42 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
Can someone please post a picture of the fender mounting hardware showing the correct position of the bolts and studs/nuts?
B5 Challenger T/A
Re: Correct Fender bolts, studs and nuts for T/A [Re: KARLN] #847478
11/06/10 05:51 PM
11/06/10 05:51 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Typically, there are three per side, from the front of the hood hinge forward like this;
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847479
11/06/10 05:53 PM
11/06/10 05:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Exceptions have been found, the other side of the same car shown above had 4;
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847480
11/06/10 07:44 PM
11/06/10 07:44 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
thanks Barry.
I checked your CD and the low mileage T/A seems to have a bolt next to the hood hinge and the rest studs/nuts.
B5 Challenger T/A
Re: Correct Fender bolts, studs and nuts for T/A [Re: KARLN] #847481
11/06/10 07:53 PM
11/06/10 07:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Same car pictured.
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847482
11/06/10 11:48 PM
11/06/10 11:48 PM
USA
rftroy Offline
rftroy  Offline
USA
Why?
I've seen this covered several times, Barry, but why was this different attachment method used on Trans Am cars?
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Correct Fender bolts, studs and nuts for T/A [Re: rftroy] #847483
11/06/10 11:52 PM
11/06/10 11:52 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The story I got (and it may be just that) is that the studs allowed faster replacement of damaged sheetmetal on the actual race cars.
Anyone got any proof one way or the other? I'll take a look through my stuff, but I do not recall it being addressed off the top of my head.......
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847484
11/07/10 12:23 AM
11/07/10 12:23 AM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Seems to me that if the fender got beat up in a race, they'd bang it out and go. Would/Did they replace fenders during races pretty regularly in the Trans Am series?
Re: Correct Fender bolts, studs and nuts for T/A [Re: jrwoodjoe] #847485
11/07/10 09:16 AM
11/07/10 09:16 AM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Not necessarily during the race, but if it got banged up in a practice session it could be swapped quicker. Just a guess.
Re: Correct Fender bolts, studs and nuts for T/A [Re: KISSAlien] #847486
11/07/10 01:28 PM
11/07/10 01:28 PM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Studs were used to hold the Shim/Washer during assembly.
Shim/washers were used under the fenders to get a better fit to the hood.
NMCA NSS 67 Coronet
Re: Correct Fender bolts, studs and nuts for T/A [Re: Barry70GTX] #847487
11/07/10 01:32 PM
11/07/10 01:32 PM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
How about this idea.....They shimmed up the center of the T/A's fender to hide or to match the bow in the hood better?
Makes more sense then for quicker pit stop changes at the race track
CHECK OUT MY NEW WEB SITE !
Re: Correct Fender bolts, studs and nuts for T/A [Re: anlauto] #847488
11/07/10 02:16 PM
11/07/10 02:16 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought there were other Challengers and Cuda documented with fender studs. Not just T/A and AAR's.
I think I still have some painted fender studs from a 70 fender I got from the junkyard 20 years ago.
Do some 72-74 E-bodies have fender studs.
I'm not buying that race story one bit. Sorry.
Spring Fling 37 May 3 & 4, 2025 at Woodley Park, Van Nuys CA
600+ Mopars, 200+ swap, midway, Friday Malibu cruise,
Re: Correct Fender bolts, studs and nuts for T/A [Re: autoxcuda] #847489
11/07/10 02:24 PM
11/07/10 02:24 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Like others I've always heard it was to make it easier shim the fender to hood alignment.. Never heard the race change out version before...
Re: Correct Fender bolts, studs and nuts for T/A [Re: 1_WILD_RT] #847490
11/07/10 03:23 PM
11/07/10 03:23 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I don't know if they changed to the stud/nut configuration on all 72-74 E-bodies or not. All I know is that my 73 came from the factory with them.
Re: Correct Fender bolts, studs and nuts for T/A [Re: burdar] #847491
11/07/10 05:45 PM
11/07/10 05:45 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have never seen a car shimmed there for any reason. Anybody else?
Re: Correct Fender bolts, studs and nuts for T/A [Re: burdar] #847492
11/07/10 05:52 PM
11/07/10 05:52 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I had read somewhere that later cars had them from the factory.
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847493
11/07/10 06:30 PM
11/07/10 06:30 PM
ontario calif
N
ns1aar Offline
ns1aar  Offline
N
ontario calif
My AAR ahd shims between the fender and the inner fender don't know why it was done though
NS1AAR
Re: Correct Fender bolts, studs and nuts for T/A [Re: ns1aar] #847494
11/07/10 06:42 PM
11/07/10 06:42 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
So did mine.
I know the hood sat higher than the fenders(in the middle)when the panels were being aligned. Shims in that area would have raised the fender so it lined up with the hood.
Re: Correct Fender bolts, studs and nuts for T/A [Re: burdar] #847495
11/07/10 08:44 PM
11/07/10 08:44 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
I have four 1971 E Bodies. Two Cudas, One Hardtop Challenger and One Convertable Challenger. The Two Cudas and the Convertable Challenger were all built prior to Dec.1970 and all have bolts. The 1971 Challenger that was built in June has the studs. I can not see any shims on these fender and they have never been off the car. This does not mean shims were not use at this time, it only means my car did not use them.
My theory is at this time May,June,July of 1971, Chrysler started to change over to the 1972 style build. Hanging fenders onto studs then aligning them is a much easier way to hang fenders on cars. There are many other things on my car that have 1972 build type pieces. Trunk floor, bumpers have slots front and back,etc. Now the fenders on T/As with studs is a story only an engineer at Chrysler could answer. What does the parts book say about the T/A fender bolts or studs. Do they list a different part number. I have never looked up if there is a break point number in the parts books for studs on a 1971 E Body.
1971 HEMI E BODY REGISTRY
Re: Correct Fender bolts, studs and nuts for T/A [Re: Alaskan_TA] #847496
11/07/10 09:14 PM
11/07/10 09:14 PM
Mississauga, Canada
KARLN Offline OP
KARLN  Offline OP
Mississauga, Canada
Barry when we removed the fenders off my T/A, we noticed shims under the fenders. It certainly looked as if the fenders had never been removed since assembly from the factory. I think the alighment with the hood comment sounds correct.
B5 Challenger T/A
