Re: carbon fiber body parts?
[Re: Scotts71chall]
#846721
11/06/10 01:55 AM
11/06/10 01:55 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Got a friend here in Phoenix, who is amazing with fiberglass, he runs a chop-top 61 falcon Wagon, and the only part that is steel is the roof..made all the F-glass quarters, doors, bumpers, front-end himself. couple of years ago he experimented with the cheap style CF, and dropped the weight of his hood from 20 to 11 lbs...so I'm confused when I hear you say the weight savings is minimal??
He made the hood, and sculpted the hoodscoop on for my Challenger's Unlimited frontend...far lighter and stiffer than the unlimited piece.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Scotts71chall]
#846722
11/07/10 10:53 AM
11/07/10 10:53 AM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
believe me, it cant be shimmed.
I`ve fixed those types of problems before. Take it off and put some heat to it. I use a propane torch,when its hot enough it starts to smell and smoke,hold it in the correct position till COOL. May take several tries and may have to go past square and let it return after cooling. May need repainted when done tho,It MAY blister the gel-coat and or paint. I`ve fixed hoods,scoops,and even doors this way. Never had one go back later once its fixed.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: cheapstreetdustr]
#846724
11/07/10 12:42 PM
11/07/10 12:42 PM
Posts: 1,805 ky hills
thehemikid
ky hills
i wouldnt say i am up on it... but a hood for my car ..with real c/f process is a grand..he quoted/threw out when i asked him. thats why i dont have one...
...I'd pay a grand for a C/F 62 dart hood with a tall M/W scoop, if it would bolt to stock hinges & work with light springs. The next problem would be shipping cost/damage. fwiw.
[Re: dOc !]
#846728
11/07/10 08:20 PM
11/07/10 08:20 PM
thehemikid
ky hills
Yo kid .... for a BOLT ON hood .... try DOUBLING that figure ..
...I was told ~3k last time i asked ~3-4 yrs ago.
[Re: jcc]
#846730
11/07/10 09:02 PM
11/07/10 09:02 PM
thehemikid
ky hills
Not sure if the first problem is the grand, the 62 dart, the MW scoop, stock hinges or light springs. Shipping cost/damage is pretty far behind IMO
And I'll have what your having
... ...I'm "having" a day dream, about night racing, in the middle of the afternoon. 2k don't sound to bad either, compared to 3.
[Re: fishy340]
#846733
11/09/10 08:17 AM
11/09/10 08:17 AM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
i agree aar is the best,but they wont make it custume!
Did you read his post??? AAR is by far NOT the best, and quite possibly the worst producer I have seen As far as Carbon Fiber is concerned another major issue with it is that it is not as forgiving (doesn't flex as much before it breaks) as 'Glass and is harder to repair.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: bwdst6]
#846736
11/09/10 12:52 PM
11/09/10 12:52 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Doc...for you to have "fiberglass" in your handle, you don't seem to up on current composites. A full body, for a pro-mod type car these days, made of glass, high quality glass, is still nearly 300 pounds. A high quality Carbon body, for that same car, from Hairy, McAmis or any of the other top composite shops, will weigh about 70lbs and cost you 8500-10,000. That is a "complete" body.
As for what parts weigh. The hood on our drag radial Buick, is a nice piece, from Glastek, weighs about 25lbs. The entire carbon front end, with the titanium tree, on the pro-mod car, weighs 12 lbs.
Carbon Fiber, is also much more durable and more flexible that regular fiberglass. I have a sheet I bought from McAmis, to make some door panels and gauge panels. You can fold the stuff double and it does not crack.
Monte
[Re: Monte_Smith]
#846737
11/09/10 01:03 PM
11/09/10 01:03 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
I have a flat sheet of carbon fiber that we used as a hood. it cracked and no one can tell me how to repair it. It is just a flat sheet with strip of styrofoam laid onto it for support , It cracked at those supports
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#846740
11/09/10 06:37 PM
11/09/10 06:37 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
When we had to patch parts on the funny car we fround down some on the bad spot and just layed carbon back over it.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
