Re: Input on launch, video attached
[Re: sshemi]
#845523
11/06/10 04:11 PM
11/06/10 04:11 PM
Posts: 352 Pennsylvania, USA
Big_Fish
Pennsylvania, USA
if it aint spinning why would you wanna adjust the suspension??? Replace converter and then start all over again.
When I got the new shocks I had taken it to a suspension shop to get a weight & balance and find the CG. They tweaked it to get it where it is now. I changed the shock settings a little to what your are seeing. Next question which is why I haven't pulled the trigger... What company for a great converter? Can I get some input for top 3? COAN, Dynamic, etc.
[Re: CHAPPER]
#845527
11/06/10 11:10 PM
11/06/10 11:10 PM
Posts: 4,132 Mo.
racerx
Mo.
Turbo Action ONLY for me...
Me Too!!!
X3
[Re: racerx]
#845529
11/07/10 12:16 PM
11/07/10 12:16 PM
Quicktree
Me Too!!!
X3
x4
[Re: Big_Fish]
#845530
11/07/10 12:34 PM
11/07/10 12:34 PM
Posts: 1,141 Phoenix,Az.
hemicop
Phoenix,Az.
If IT WERE ME---since you already have a 5500 stall converter (good, I hope) I'd first make sure I was leaving while up against the converter. I had a similiar equipped but MUCH heavier car & would 60ft in the 1.30-1.33 range. Don't know what tire pressure you're running, but we almost always ran around 9psi. one way or another I'd find some way to loosen up that front end & for that matter, later on, if you have no luck, perhaps even lighter rear springs so as to the allow the back end end to squat---it looks like your back-half isn't working either. For me, if the car "pitches", your suspension isn't working evenly which could cause or is a sign of another problem---just MY , but hey!----you asked...
[Re: moparguy7074]
#845532
11/07/10 04:29 PM
11/07/10 04:29 PM
Posts: 2,128 sweden
sshemi
sweden
Why would you want more susp travel if it aint spinning?? All other movement eccept forward will slow the 60 down. Besides i dont know if your 60 is bad at all? Besides pulling a little to the right, that chassie looks sorted out to me.
[Re: moparguy7074]
#845533
11/07/10 04:36 PM
11/07/10 04:36 PM
Big_Fish
Pennsylvania, USA
Im surprised nobody mentioned rear gear. Isnt a 4.56 with 33" tires to high? I would think thats why mph is on the high side, but 60' is slower. Dont most cars with big tires run a taller gear?
I was thinking of putting 4.88's when I went from 32 to 33" tires. I run 10.5 lbs of air pressure in the tires. I think this winter I'll start with a new converter, then front coil overs to get more travel in the front end and then see what happens at the track before I change anything else.
