Re: reg slicks to drag radial lower et
[Re: HEMIFRED]
#845383
11/04/10 12:27 PM
11/04/10 12:27 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The radial, of comparable size, provided you can hook it, will be faster than the bias tire, every time. The radial tire construction, is simply better. Yes the sidewall is stiffer, but the tire as a whole is stiffer. The tire stays more "round" during the run, which is quicker and faster. We run both slicks and radials. With identical tune ups and identical 60fts, the 330 and 660 numbers, are quicker with radials, EVERY time.
Monte
[Re: Monte_Smith]
#845384
11/04/10 12:33 PM
11/04/10 12:33 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Monte
But when the hook goes away it won't recover without pedaling on a car with any power. Even when pedaled it's hard to get them stuck again. I know these tires are resposible for some fan interest.
[Re: BobR]
#845387
11/04/10 01:09 PM
11/04/10 01:09 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
This is hard to articulate, but I'll try. I always consider that most all things your car does takes energy to make that thing happen. This energy is supplied in the form of torque from the motor. Anything that takes energy without effectively moving the car forward steals that much energy / power from your ultimate goal of getting to the stripe. Now, A bias tire with softer sidewalls flexes much more at the sidewall (and I believe in the treadpatch) than a radial tire. Flexing the tire takes energy. This energy that is used to flex the tire is energy that dies in the tire, and is not transferred to the track. The stiffer radial tire flexes less, and thus is more effective at transferring all the energy its recieving into rolling force. The flex is also what makes them hook, so its a double edged sword. But, as said, as long as the radial tire hooks, you're now using more effective energy to push you forward, as less is spent flexing the tire. I think this same principal can be applied to rear suspension (but thats another discussion). Also, as far as growth. My philosopy here is that growth will only help if you're at the end of your motor's power range, and it needs more gear. If you're still in your effective power range at the top of the track, then you don't want growth, the lower effective gear ratio offered by the non-growing tire will offer acceleration at a faster rate than the higher effective gear. These are merely my thoughts as a reasonably intelligent person, offered up for discussion. Your thoughts may vary.
[Re: BobR]
#845388
11/04/10 01:59 PM
11/04/10 01:59 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Monte
That's it exactly. Once mine decide to fry, then the run's done...no ifs,ands, or buts. Only way to get them to hook after that is either back peddle severely or try an upshift(short shift) to the next gear. Personally, when my radials loose it, I can easily cover the whole width of the track for the first 300 feet....sometimes not a fun ride. Great for the fans, but hell on the driver.
[Re: tboomer]
#845389
11/04/10 02:20 PM
11/04/10 02:20 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Are we discussing treaded radial race tyres or radial slicks? I've found that a radial slick will et and 60ft better but are not as forgiving on less well prepped tracks. I've no experience with the treaded radial race tyres but have listened to many tales of mixed results with them, seems they will work well on a good track, similar to the above.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
