Page 2 of 4 1 2 3 4
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: GO_Fish] #84384
07/06/08 10:14 AM
07/06/08 10:14 AM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I know when i run rotella in my cummins it smells bad. I can smell it in my cab and in the flumes.I run Delvac in my cumins.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: Anyone using Rotella Diesel oil in their musclecars [Re: hulmule] #84385
07/06/08 10:39 AM
07/06/08 10:39 AM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
Yes I use 15w 40.
Re: Anyone using Rotella Diesel oil in their musclecars [Re: 68Bullit] #84386
07/06/08 01:25 PM
07/06/08 01:25 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
What about the Chevron Delo 400? It's the same weight, but is it the same or better than the Rotella? And as far as the weight goes, is there really a big difference in the 10W and 15W?
Chevron Delo 400 LE 15W40 actually has more zinc than Shell Rotella T 15W40. I don't remember exactly, but it's above 1300 ppm zinc. At least 1200 ppm zinc is best for a flat tappet cam. I suppose 1150 ppm zinc (approximate) is OK, such as Shell's Rotella T's, for a stock engine or a mildly built engine. That's up to the individual to decide.
Shell Rotella T 5W40 full synthetic has about 1400 ppm zinc.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Anyone using Rotella Diesel oil in their musclecars [Re: Junky] #84387
03/17/15 06:54 PM
03/17/15 06:54 PM
Ontario Canada
3
300_dup5 Offline
300_dup5  Offline
Ontario Canada
Thanks Guys, new 440 here it comes
Re: Anyone using Rotella Diesel oil in their musclecars [Re: 300_dup5] #84388
03/17/15 08:27 PM
03/17/15 08:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
6-7 year old thread?
Re: Anyone using Rotella Diesel oil in their musclecars [Re: Challenger 1] #84389
03/17/15 08:33 PM
03/17/15 08:33 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Don't worry, oil additive packages haven't changed in the last 6-7 years.
Re: Anyone using Rotella Diesel oil in their musclecars [Re: B5 Bee] #84390
03/17/15 09:35 PM
03/17/15 09:35 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Diesel oil will foam at high RPM.
Call Rotella and ask them if it is suitable for your application.
Re: Anyone using Rotella Diesel oil in their musclecars [Re: Challenger 1] #84391
03/17/15 11:06 PM
03/17/15 11:06 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
For the last 30 years all I've used in everything from a brigs and Stratton to my 605 Hemi is shell rotella 15/40 HD diesel oil. Never had an oil related engine failure with it.Dave
Re: Anyone using Rotella Diesel oil in their musclecars [Re: quickd100] #84392
03/17/15 11:38 PM
03/17/15 11:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Same here. Muscle motors even used Rotella when they dynoed my 526 Hemi.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: hulmule] #84393
03/17/15 11:53 PM
03/17/15 11:53 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Yeah, I can vouch for that smell. I used it a couple of times in my '02 CTD. And I will probably use it when I finally fire the motor in the Ramcharger (it has been dormant since 2012 and it does not look to good for 2015). That 440 has a hot Comp hydraulic and I don't need lifter problems.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: Polarapete] #84394
03/18/15 01:21 AM
03/18/15 01:21 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
I found this compilation last year searching for updated oil/zinc info, found it helpful.
Re: Anyone using Rotella Diesel oil in their musclecars [Re: NITROUSN] #84395
03/18/15 08:40 AM
03/18/15 08:40 AM
Georgia
Steve Bryant Offline
Georgia
Last year when we rebuilt my 440, the engine builder recommended it and that is all I have used. Its a driver and so it very rarely seem RPMs over 4,000.
Re: Anyone using Rotella Diesel oil in their musclecars [Re: Steve Bryant] #84396
03/18/15 10:24 AM
03/18/15 10:24 AM
Ohio
jlatessa Online content
jlatessa  Online Content
Ohio
My engine builder recommended it (30 wt.) for cam break-in
and VR-1 10W30 for use after that. This with a 284/.484 hydraulic.
6200 RPMs max.
15 dyno runs later, no blow-by and good looking cam lobes.
Of course, viscosity choice is clearance and oil pressure
dependent.
Joe
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #84397
03/18/15 11:02 AM
03/18/15 11:02 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I am using it with a comp 509 cam and eddy heads with their springs. I do put a bottle of richard petty's STP additive (which had a lot of zinc for an additive) to get 6 qts.. I bought a bunch of bottles of this petty stuff when big lots was clearing it out for $2 a bottle. Whether or not it helps, who knows, but it's been working.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #84398
03/18/15 11:16 AM
03/18/15 11:16 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Nope....Bradd Penn at breakin and down the road
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: terzmo] #84399
03/18/15 11:22 AM
03/18/15 11:22 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Don't use the CJ rated oils. They are for 07.5 and newer diesels with the particulate filters and have zippo for ZDDP. Use a CI rated if you want to use diesel oil and make sure its not combo'd as CI/CJ.
Carl Kessel
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: Polarapete] #84400
03/18/15 01:30 PM
03/18/15 01:30 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I use it all the time, my truck even leaks oil and yet I never noticed any kind of smell
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: Silver70] #84401
03/18/15 03:22 PM
03/18/15 03:22 PM
an8sec70cuda Offline
I didn't really notice it until I relocated the puke tank on my '01 Cummins, but right after an oil change it does have a weird smell. Kind of an acidic smell. It seems to go away after a while...maybe as the oil gets some miles on it.
I always run Rotella in my truck, but I use Valvoline VR1 race oil in my cars.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: CKessel] #84402
03/19/15 10:53 AM
03/19/15 10:53 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I think Rotella and Delo 400 CJ-4s have about 1200-1300 ppm of zinc. I've been running it for years as have many others.
Re: Anyone using Rotella Diesel oil in their musclecars? [Re: pinkduster] #2390920
10/21/17 06:28 PM
10/21/17 06:28 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Reviving an old post; what's the attractiveness of the 20W-50 weight of the VR-1 Valvoline. I've had it recommended to me by very experienced Mopar mechanic, and I know a lot of wise Mopar people who like it. I'm just wondering, aside from the Zinc content, what's the advantage of the weight?
Would you recommend that weight in my stroked 360, hydraulic roller cam, Florida temps, no racing, just some occasional heavy footed street driving?
Facts are stubborn things.
Page 2 of 4 1 2 3 4
