Re: rockers [Re: MoparforLife] #843731
11/03/10 01:03 PM
11/03/10 01:03 PM
Az
Crizila Offline
Crizila  Offline
Az
rocker ratio testing tool.
Looks like a good tool but will it make compensation for push rod angle? It is a lot of work but we do it right on the engine with a lifter shimmed solid at the preload we are using. Very time consuming but about as accurate as you can get per application.
No, it's just for testing / comparing / plotting rocker ratios. Your way is the best if you want to include any "outside influences".
Fastest 300
Re: rockers [Re: Crizila] #843732
11/03/10 01:49 PM
11/03/10 01:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
That tool would be handy to insure a full set of rockers with the same values. It may take several sets to make up one well matched one. (Been there - Done that)
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: rockers [Re: 65dragnet] #843733
11/03/10 05:20 PM
11/03/10 05:20 PM
AndyF Offline
AndyF  Offline
Are stock max wedge rockers worth anything ? Do they make good race rockers ?
The MW rocker arms are just fine up to a point. They should work perfectly well on any flat tappet cam and will even work on a small street type roller cam. Same thing goes for the Isky nodular arms and maybe even the Crane iron rocker arms.
I switched over to the RAS stainless arms a few years ago and that is almost all I use anymore for moderate performance engines. For the really killer motors you have to step up even more to T&D or Jesel.
It all depends on how much power you want to make and how deep your wallet is. Your question was so vague that nobody can answer it so we are all just guessing what you ment by "race rockers". You aren't going to find original MW rocker arms on very many race cars that go rounds at NHRA events, but you might find them on a local bracket racer.
Re: rockers [Re: AndyF] #843734
11/03/10 07:44 PM
11/03/10 07:44 PM
Indiana
65dragnet Offline OP
Indiana
bracket racing is where it's at ! ( I see a can of worms coming). That's what the query was set for. I realize that high horsepower high $ racer would never resort to these kind of rockers. Just have some laying around and was wandering if anyone ever used them with success in a bracket car of circa 6 to 700 horsepower !
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: rockers [Re: 65dragnet] #843735
11/03/10 09:03 PM
11/03/10 09:03 PM
AndyF Offline
AndyF  Offline
600 hp wouldn't be a problem. Good luck with the 700 goal with those rocker arms. Maybe Indy EZ heads with a big flat tappet cam would get you there but I think you would be scrubbing the valve tips pretty hard. Not really the smartest way to build a motor.
