Re: rockers
[Re: 65dragnet]
#843733
11/03/10 05:20 PM
11/03/10 05:20 PM
Posts: 31,061 Oregon
AndyF
Are stock max wedge rockers worth anything ? Do they make good race rockers ?
The MW rocker arms are just fine up to a point. They should work perfectly well on any flat tappet cam and will even work on a small street type roller cam. Same thing goes for the Isky nodular arms and maybe even the Crane iron rocker arms.
I switched over to the RAS stainless arms a few years ago and that is almost all I use anymore for moderate performance engines. For the really killer motors you have to step up even more to T&D or Jesel.
It all depends on how much power you want to make and how deep your wallet is. Your question was so vague that nobody can answer it so we are all just guessing what you ment by "race rockers". You aren't going to find original MW rocker arms on very many race cars that go rounds at NHRA events, but you might find them on a local bracket racer.
