Cal-tracs and SS springs #843468
11/01/10 01:37 PM
11/01/10 01:37 PM
Champion City
The Sphinx Offline OP
Champion City
Has anyone ever tried it?
I hear not to, but never got a reason why not.
Re: Cal-tracs and SS springs [Re: The Sphinx] #843469
11/01/10 02:30 PM
11/01/10 02:30 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Spend some time hacking around w/ the Search feature going back a few years and I'm sure you'll find multiple threads on exactly this topic.
Re: Cal-tracs and SS springs [Re: The Sphinx] #843470
11/01/10 06:43 PM
11/01/10 06:43 PM
Georgetown, TX
sc4579 Offline
sc4579  Offline
Georgetown, TX
Been using them for 5 years now with SS springs on my Dart Sport. Very consistant 60 foots, 1.40-1.42. Just using Monroe shocks on the rear, the bars in the lower hole. I set the preload on the bars with my weight in the car and have had no problems. Car weighs 3290 with me in it, and a small block pump gas motor, with 904 transmission and 4.88 gears.
2023 Challenger Scat Pack 1320
2016 Jeep Renegade
Re: Cal-tracs and SS springs [Re: sc4579] #843471
11/03/10 09:57 PM
11/03/10 09:57 PM
K
Kiddart Offline
Kiddart  Offline
K
if this works why does calvert tell you not to do it? they say to use a light duty spring. If you truely can do this its helps guys out like me that want to run the mono leafs but cant buy every thing at once. Can anyone else add to this please I have looked in the archives with very little sucess. Monte if you read this maybe you can shed some light on us.
1Qwkdart
Thank you
Kiddart
Re: Cal-tracs and SS springs [Re: Kiddart] #843472
11/03/10 11:13 PM
11/03/10 11:13 PM
Rittman Ohio
fourgearsavoy Online tonguue
fourgearsavoy  Online Tonguue
Rittman Ohio
I tried it and my car would do weird stuff like jump and unload the tires then it would go perfect next pass Guy I got the bars from told me to get the monoleafs and then hooked hard and straight every time after that
Gus
64 Plymouth Savoy
Dana 60
Re: Cal-tracs and SS springs [Re: fourgearsavoy] #843473
11/04/10 09:47 AM
11/04/10 09:47 AM
Raleigh N.C
hemiparts Offline
"Missile Pilot"
hemiparts  Offline
"Missile Pilot"
Raleigh N.C
Re: Cal-tracs and SS springs [Re: hemiparts] #843474
11/04/10 10:03 AM
11/04/10 10:03 AM
Port Mcneill,B.C.Canada
I
Islandcuda Offline
Islandcuda  Offline
I
I used them for a few years, then bought the monoleaf, to be truthfull there was an improvement over the car bouncing at launch, with ss springs, bounced every time, but did it the same every time and was consistent. With the mono,s car settld down, but the odd time, would get the bounce, but not as severe. I can only assume track conditions dictated a lot, car was still consistent, just the odd time ,and of course calvert tells ya not to use them, they are the seller taking your money, Tim
67 cuda new best 1.395 60 10.240 at 128.58mph
Re: Cal-tracs and SS springs [Re: Islandcuda] #843475
11/04/10 10:14 AM
11/04/10 10:14 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
The reason Calvert wants you to buy his mono spring because with s/s springs and the bars there is not enough shock that can control all that and that is why you are getting your bounce. There is not a shock out there that can control that. With the mono the spring is just holding up the car and the bar is doing all the work. You would get way to much and too fast of body separation and not get the tire to plant and hold with s/s springs and cal tracs.
JAKES AUTOMOTIVE
Re: Cal-tracs and SS springs [Re: JAKE68] #843476
11/04/10 11:57 AM
11/04/10 11:57 AM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
i ran SS springs and 3 way adjust shocks for 10 years--and they worked very well--------
then i spent the $$$ on the complete caltrac setup with the 9000 ranchos and WOW--i recommend this set up if you are running 10's or faster (in my opinion)
i've been running NOS for 15yrs and now N.A. and going 8.90s--doing 1.29 60ft and i love the adjustability i have at the tracks with this set up
ross
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: Cal-tracs and SS springs [Re: ROSSIO] #843477
11/04/10 12:33 PM
11/04/10 12:33 PM
PA
ajcasini Offline
ajcasini  Offline
PA
I ave used cal-tracs with the SS Springs for about 5 years now. They worked great for aobut the first 3 years now I am getting too much body separation. I have not experienced the bounce that was mentioned earlier. Even with the extra body life car was deadly. My main issue is the car would lift more than go forward on the line and this hurt RT. I am ordering the mono-leafs for my car this winter.
My car has gone as fast as 10.60 and as slow as 11.30 during these 5 years.
Re: Cal-tracs and SS springs [Re: The Sphinx] #843478
11/04/10 12:51 PM
11/04/10 12:51 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Anyone tried it - YES
So, can you use Cal-Tracs with ss springs - YES
Is it optimal - NO
From my understanding on how the Cal-Trac bars work, part of the "leverage" the Cal-Tracs use to plant the rear tire is provided by the wrap-up of the front spring segment. The SS springs were designed with a stiff front segment to reduce spring wrap-up. Therefore they don't provide as much force on the Cal-Trac pivot bar, resulting in less downforce at the axle. Still more downforce than without the bars, but not as much as with a "softer" front spring segment.
Also with the Cal-Trac system, according to John Calvert, you want 5-inches of front suspension travel from resting static, to just before the wheel come off the ground. This movement is needed to get additional rotational weight to the back tires, again resulting in more downforce to the rear tires.
A lack of adequate front suspension travel can result in "unloading" of the tires a few feet off the line. Some of the unloading can be controlled with shock settings, but proper front suspension travel should cure most of an unloading issue.
Scott
Re: Cal-tracs and SS springs [Re: ProStDodge] #843479
11/04/10 02:28 PM
11/04/10 02:28 PM
organ
maximum entropy Offline
organ
trying not to hijack here (and failing?). could one remove some leaves from the ss springs and get more satisfactory results?
Re: Cal-tracs and SS springs [Re: maximum entropy] #843480
11/04/10 03:16 PM
11/04/10 03:16 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
as long as the springs are symetrical left to right they will work better.
biased rate side to side does not help with launch.
As stated earlier all the spring does is hold the car up.
Re: Cal-tracs and SS springs [Re: theclutcher] #843481
11/04/10 04:26 PM
11/04/10 04:26 PM
scratchnfotraction Offline
any one run the split mono leaf?
how much do the 2 halfs overlap?
which leaf is on top..front or rear segment?
on my 85 shortbed truck,I have the axle on top of the rear springs with a shackle flip
and thought of makeing my own set of split mono leafs for the caltracs sytsem from 2 sets of main leafs from truck spring packs
or would that be to hickabilly
Re: Cal-tracs and SS springs [Re: scratchnfotraction] #843482
11/04/10 06:58 PM
11/04/10 06:58 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
had my local spring co make 1 pc 1/2" monos 10 years ago, still fine.
Re: Cal-tracs and SS springs [Re: theclutcher] #843483
11/05/10 03:09 AM
11/05/10 03:09 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
Very , very interesting thread.
subscribing .
Re: Cal-tracs and SS springs [Re: 493_DART] #843484
11/05/10 08:36 PM
11/05/10 08:36 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I know people that have used them with SS springs with no issues. I think it depends on how much power you're making.
Re: Cal-tracs and SS springs [Re: cudadoug] #843485
12/17/11 04:47 AM
12/17/11 04:47 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
I need to bring this topic back.
I tried the Caltracs with my SS springs. Many times.
I went thru EVERY possible adjustment over several races.
I could not make them work--the car would bounce and "porpoise" on launch.
So , dont waste your time. I already did that for ya.
Buy their mono spring .
Re: Cal-tracs and SS springs [Re: 493_DART] #843486
12/17/11 09:24 AM
12/17/11 09:24 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
How are Cal-tracs with stock, non SS springs? Those should let bars work better than the SS's , right?
Re: Cal-tracs and SS springs [Re: JAKE68] #843487
12/17/11 10:18 AM
12/17/11 10:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
the Rancho is just barely enough shock
for a standard spring and the Caltracs... so with
the SS spring you get way to much separation to quick...
also makes a difference on how much torque your throwing
at the rearend
