Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843297
11/06/10 10:34 PM
11/06/10 10:34 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I'll be honest. The money I have in the roller valve train and as hard as I spin it, it scares the crap out of me. When I first put it on alcohol this summer, I was a mess when I fired the car up. All of a sudden the car was quieter and I could hear noises in the valvetrain that on gas I couldn't. Now when I lean the fuel out, it goes right back to its snotting self.
Beep
Are you on straight alcohol or E85? Whiskyrunner is making the switch to alcohol next year and I may try E85.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Loosing lash on one valve........ Ever had it? [Re: pittsburghracer] #843298
11/07/10 12:37 AM
11/07/10 12:37 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
John,
If you put all new lifters in I would go with Lunati. The link bar setup is a ton better than the Comps. I have had bad luck with their lifters. The Ferara valves are nice, that is what I put in about all my builds. Inspect the cam bearings as well to make sure you don't have one spinning with the cam it will cause a valve to tighten as well. Good luck with it. poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Loosing lash on one valve........ Ever had it? [Re: poppaj] #843299
11/07/10 08:47 PM
11/07/10 08:47 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Pittsburgracer, Straight alcohol
Poppa J, Thanks for the heads up.
Beep
Re: Loosing lash on one valve........ Ever had it? [Re: Bigbeep] #843300
11/07/10 09:25 PM
11/07/10 09:25 PM
PA.
"Little"John
"Little"John
PA.
Beep
Thanks, may have to try that stuff someday. E85 would kinda be a pain in the butt as the closest place that sells it is 25 miles out of my way. I could buy alcohol right at the track.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
