69 Dart GTS oiling system losing prime after sitting?
#841887
10/30/10 09:07 AM
10/30/10 09:07 AM
Posts: 15,996 RI Deep in the rust belt
chargervert
A friend of mine has a matching numbers 69 Dart GTS 383 4 speed car. Since he put the car away last winter,the car has had no oil pressure on start up after sitting. If he pulls the coil wire off before starting it up,and cranks it over until it shows oil pressure on the mechanical guage,then its fine until the next time it sits,then it's the same scenario. He has replaced the oil pump three times,with three new,different pumps,and it does the same thing. This summer he drove it to a few shows that were a couple hour rides,and after diving the car alot,it didn't have the problem,until it sat for the last two weeks,then after trying to fire it up again,it was knocking and clacking until he shut it off,and primed it with the coil wire off again,then it was fine. He needs help figuring this out,as the car has the matching numbers engine,and he dosen't want to hurt it. He is getting ready to drop the pan to see if there are problems with the pickup to the oil pump. Any ideas as to what else could cause the loss of prime issue,after sitting?
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
Re: 69 Dart GTS oiling system losing prime after sitting?
[Re: JohnRR]
#841891
10/30/10 11:21 AM
10/30/10 11:21 AM
chargervert
I just spoke to him on the phone,and he said he changed the oil and filters every time he swapped oil pumps. The filters were WIX filters.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#841892
10/30/10 11:27 AM
10/30/10 11:27 AM
RapidRobert
that eliminates the filter as the culprit
[Re: RapidRobert]
#841893
10/30/10 11:31 AM
10/30/10 11:31 AM
chargervert
After what I read about the Fram filters I run WIX filters on all my cars.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#841894
10/30/10 11:36 AM
10/30/10 11:36 AM
Posts: 2,533 God's Country Maryland
GODSCOUNTRY340
Have him pull the oil pan and clean the valve seal pieces out of the pickup tube screen, it must be nearly clogged.
[Re: GODSCOUNTRY340]
#841895
10/30/10 11:40 AM
10/30/10 11:40 AM
chargervert
I suppose it's possible,but the engine was rebuilt about ten years ago. It dosent puff any oil on startup,like most cars would if the valve seals were bad.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#841896
10/30/10 01:23 PM
10/30/10 01:23 PM
RapidRobert
I reread your (original) post. I'm assuming it wasn't always like this but now (after this particular extended storage) it clatters real bad & it didn't b 4? How long does he now have to crank it w the coil disabled b 4 the psi come up? OT but I'd suggest he ground the coil wire rather than making an open circuit but if we can fix the prob that'll take care of that .
[Re: RapidRobert]
#841897
10/30/10 01:36 PM
10/30/10 01:36 PM
chargervert
The oiling issue started this June,when he broke the car out of winter storage. After the engine cranks about twenty turns it starts showing oil pressure on the guage. once it gets prime the car is fine no matter how many times he runs it. After it sits overnight,it has the same problem the next time he trys to fire it up. If the problem persits after he pulls the oil pan,I will suggest a kill switch,so he can crank it safely,without it firing until it's primed. Plus it may stop a potential thief too.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#841898
10/30/10 01:44 PM
10/30/10 01:44 PM
RapidRobert
Yeah it's gonna be interesting to find what happened (what got stuck/or cracked open) while it was sitting immobile in storage and whether it's downstream or up stream from the pump as it isn't the pump or filters will all of that changing out that he did
[Re: RapidRobert]
#841899
10/30/10 03:10 PM
10/30/10 03:10 PM
chargervert
Yeah,thats not the easiest task in a big block A body!
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
