Re: NORMAL COMPRESSION???
[Re: Labratt]
#841572
10/29/10 05:51 PM
10/29/10 05:51 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
There might be, but hard to say when you have large overlap cams bleeding compression out the exh valve. When you test, make sure you run the test the same way. Like warm the engine up, and test with the carb at WOT. Make sure the battery doesnt run down so you have the same cranking power. This can effect the numbers, or if the engine cools etc. Look at each cylinder and they should be with in 5% of all others. I like my race engine in the 225-250 lbs + range. I healthy street engine should approach 200 psi. But many factors come in play here ![](/ubbthreads/images/graemlins/Twocents.gif)
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#841576
10/29/10 07:24 PM
10/29/10 07:24 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my 14-1 small block stroker with a solid roller with 267/272 @ 50 only has 190# and the leakdown is less than 3% and it runs 6.32 at 109 in the 1/8 in a car that is 2975 lbs.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Bob_Coomer]
#841577
10/29/10 07:25 PM
10/29/10 07:25 PM
Posts: 1,049 ohio
all spooled up
ohio
my small block 230-235 psi cam is solid roller 650 lift duration at .020 in 296 exh 303 @ .050 263 270 in at 106 ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: all spooled up]
#841579
10/29/10 08:58 PM
10/29/10 08:58 PM
Posts: 3,695 nc
emarine01
nc
Whats the compression ratio?
[Re: emarine01]
#841580
10/29/10 09:02 PM
10/29/10 09:02 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Based on the PSI though, I will guess, 13.5 or more ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: Thumperdart]
#841581
10/29/10 09:25 PM
10/29/10 09:25 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Guess our junk`s wore out.
No, ![](/ubbthreads/images/graemlins/tsk.gif)
Just points to how inaccurate a compression test is at telling you anything.
About the only thing you can learn from one is if you took one and wrote it down when the engine was built and then compared it to when you think you may have a problem.
I prefer a leak down test myself.
[Re: Labratt]
#841585
10/30/10 01:37 AM
10/30/10 01:37 AM
Sport440
Canton, Ohio
Thats more like it. On one of your other threads you registered 185 PSI witch I felt was high for your combo. IMO with around 10.25 Comp and that 262* cam your 170-175 PSI is in the normal range for the combo. Maybe even a little high. But, FWIW, the Calulater that Dodgem posted was Happy about by 20# PSI for my Combo. But with your engine specs, it was almost right on. ![](/ubbthreads/images/graemlins/shruggy.gif) mike
[Re: Bob_Coomer]
#841586
10/30/10 10:44 AM
10/30/10 10:44 AM
Posts: 4,213 New York
polyspheric
New York
How exactly does this happen?
Boffin Emeritus
[Re: polyspheric]
#841587
10/30/10 10:56 AM
10/30/10 10:56 AM
Posts: 4,321 Prospect, PA
BSB67
Prospect, PA
...out the exhaust valve" ???????
[Re: Labratt]
#841588
10/30/10 11:07 AM
10/30/10 11:07 AM
BSB67
Prospect, PA
I just checked a couple of cylinders for S&G's! One was 175psi..the other was 173 or so! Didn't know about holding the carb open,though! Thanks fella's! RandyB
If your doing it for S&G, and you like data, pick a cylinder, get a good consistant technique and baseline numbers, then change your intake lash plus 0.004" and minus 0.004". And then of course report back
[Re: BSB67]
#841590
10/30/10 12:24 PM
10/30/10 12:24 PM
polyspheric
New York
Which cam is that where the exhaust valve is open during the compression stroke?
Boffin Emeritus
