Re: 318 info for my rod
[Re: RodStRace]
#841550
10/30/10 12:00 AM
10/30/10 12:00 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Two things prevented the 318 from fitting into the Sunbeam. Rear mounted distributor and length. SBF is shorter in length and height and has a front distributor.
Maybe a Magnum, which is short than an LA 318, and some sort of coil pack ignition might make it fit, you will need to measure.
[Re: 67MIke]
#841554
10/31/10 09:20 PM
10/31/10 09:20 PM
Supercuda
About to go away
About to go away
up yours
Timing cover and pump are shorter, not sure how much. The LA is definately longer and wider and taller than the SBF.
