Re: 69 440
[Re: 451Mopar]
#841306
11/03/10 12:03 AM
11/03/10 12:03 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i already have a forged crank from a D-440 block, i also have the rods, i really want a better compression engine, i already have a 73'motorhome motor in my car now, i was trying to get a more correct motor for my car, i think i will take my crank to the machine shop and see if it is any good and also pull off the head to see what i have for pistons and then i guess i can make a better choice, i really do not want to sell this motor then because of the lack of motors around my area, Jackson MS, i have a good starting point to build a good street motor thanks Randy
Re: 69 440
[Re: RoadRunnerJD]
#841308
11/03/10 12:08 AM
11/03/10 12:08 AM
cornet684me
Brandon, Ms
thanks RoadRunner JD, i really did not want to hear this, but after 3.5years of this project nothing surprises me anymore, this project has really tested my patience, coming from chevy to mopar has been a really learning experience, however once i have the mopar built, i will have something, the chevys are dime a dozen, i just hope i do not have to cash in my 401k to finish it
Re: 69 440
[Re: JohnRR]
#841312
11/03/10 12:19 AM
11/03/10 12:19 AM
cornet684me
Brandon, Ms
thanks JohnRR , i will post my findins when i pull the head, i have go a better of mine that can help me pull the head, i do not know when i can do this, however, when i do , i will post my findings
Re: 69 440
[Re: cornet684me]
#841315
11/03/10 02:04 AM
11/03/10 02:04 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
More info always helps. What is the engine going into? What is the application? (daily driver, street, performance, race?) What transmission, stall speed, rear gearing, tire size? What are your performance expectations? What are your budget expectations?
Also, you don't have to pull the heads. You could turn the engine on the engine stand to where the spark plug is the highest point. set the piston to TDC (both valves closed or remover rocker arms), and cc the chamber volume directly by filling through the spark plug hole.
Assuming a 0.030" over bore (4.350" bore x 3.75" stroke) the piston swept volume should be 55.73 cid = 913.44 cc's. Here is a list of chamber volumes above the piston at TDC and what the compression ratio would be: CC's CR 90 11.16 95 10.62 100 10.13 105 9.70 110 9.30 115 8.94 120 8.61 125 8.31 130 8.03
You would want to cc the chamber using some oil so it won't run past the ring gaps, or cause rust in the chamber/bore.
Re: 69 440
[Re: 451Mopar]
#841316
11/04/10 12:11 AM
11/04/10 12:11 AM
cornet684me
Brandon, Ms
What is the engine going into? 68'dodge coronet
What is the application? (daily driver, street, performance, race?) street car
What transmission, stall speed, rear gearing, tire size? 727/stock convertor/ 3.55 275/60/15
What are your performance expectations? good sounding driveable street car
What are your budget expectations? cheap as possible
Re: 69 440
[Re: cornet684me]
#841319
11/04/10 12:31 AM
11/04/10 12:31 AM
451Mopar
Aurora, Colorado
so i wld measure out the cc's of oil it wld take to fill up the #1 cylinder at tdc on the compression stroke, and if my motor is bored 30over i wld use the chart you post?
Yes. No need to tear the engine apart. You could also measure/degree the cam to figure out what duration size it is, what the max lift is, and how it is installed.
With your stock setup, and for street application you may not want to change much. You could install some cheap 1.7:1 rocker arms to get more performance from the cam you have.
Example: CAT 1.7:1 Stainless steel rocker assembly $360.
http://www.catpep.com/searchengine/searchengine.asp?parttype=27&enginetype=13
