4 banger trouble-shoot .... #841244
10/28/10 11:51 PM
10/28/10 11:51 PM
Florida STAYcation
dOc … Offline OP
The village idiot's idiot
dOc …  Offline OP
Florida STAYcation
90 caravan 2.5 ..... NO spark and no power to the fuel pump ... the pump checked fine on-the-bench.
I messed my hand up and I can't work on it.
NO codes to the best of my knowledge ..... ANY suggestions? (bad PU in the distrib?)
THX
Re: 4 banger trouble-shoot .... [Re: dOc …] #841245
10/29/10 02:10 AM
10/29/10 02:10 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Auto shutdown relay (ASD) i think can cause no spark and no fuel but not 100% on that
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 4 banger trouble-shoot .... [Re: sreinheimer] #841246
10/29/10 02:53 PM
10/29/10 02:53 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
THX ....I will have him check that. What is the purpose of that relay ?
Re: 4 banger trouble-shoot .... [Re: dOc …] #841247
10/29/10 03:05 PM
10/29/10 03:05 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
It provides 12v to the fuel pumps, ignition coil, injectors, etc...
Basically so that it kills fuel pressure when the key is turned off to prevent fires, run on, etc...
Re: 4 banger trouble-shoot .... [Re: chache876] #841248
10/29/10 03:15 PM
10/29/10 03:15 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
COOL ... sounds like that is the ticket ! My bud has the Haynes manual and the vehicle ...so I must ask ...WHERE is that relay in the car?
Re: 4 banger trouble-shoot .... [Re: dOc …] #841249
10/29/10 03:29 PM
10/29/10 03:29 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
I'm not 100% sure on that vehicle but they're usually on the firewall in a group of 3 relays. The haynes manual will tell you for sure.
Re: 4 banger trouble-shoot .... [Re: chache876] #841250
10/29/10 10:31 PM
10/29/10 10:31 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
On the P-body cars, all three relays are between the battery and the brake booster. Its one of the three. The wiring diagram will show what wire colors to look for.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 4 banger trouble-shoot .... [Re: Dave_J] #841251
11/01/10 10:30 AM
11/01/10 10:30 AM
North Central Indiana
C-Tech Offline
C-Tech  Offline
The pick up coil is much more likley to be bad then the ASD relay, check for power to the coil on the + side when you first turn the key on should power up for 3 seconds if you have power there the ASD is working properly. the fuel pump and coil are powered by the ASD but the computer will not turn it on if it does not see a signal from the pick up coil while cranking.
Kevin
Re: 4 banger trouble-shoot .... [Re: C-Tech] #841252
11/01/10 02:23 PM
11/01/10 02:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Incorrect. The computer will prime the fuel pump even before you start cranking. When you put the key to the run(but not crank) position you should hear the fuel pump for a few seconds. The pickup fires off the injectors and you are right in that the fuel pump will not continue to run past the 3 second prime if there's no signal from the pickup in the distributor, but it will still prime when you turn the key to run. It will only try to prime a set amount of time per start cycle but I don't remember how many times that is. Maybe 5 or 6 times if memory serves.
The older years had the ASD relay built into the ECU but by 1990 it was a seperate relay. On the cars at least it's around the drivers side strut tower area. Not sure about the minivnas.
Re: 4 banger trouble-shoot .... [Re: DaytonaTurbo] #841253
11/01/10 03:21 PM
11/01/10 03:21 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
But if it does prime the fuel rail for that 3 seconds, it will do it once untill the pressure bleads down.
If it does prime and crank over but will not start, pull the disrtibator cap and see if the "rotor" rotates while cranking. If not, broken Timing belt could be the cause. VERY COMMON! Unless its a highly modified 2.2/2.5 with a high CR and high lift cam, they are a NON interferance engine and all should be ok if the belt breaks.
65 Formula S Cuda
Re: 4 banger trouble-shoot .... [Re: DaytonaTurbo] #841254
11/03/10 01:47 PM
11/03/10 01:47 PM
C-Tech Offline
C-Tech  Offline
Check you wiring schematics it primes the Fuel pump by cycling the ASD There is no separate wire to the fuel pump only the ASD that is why the coil is hot for those same 3 seconds. So I am not "Incorrect"
Kevin
Re: 4 banger trouble-shoot .... [Re: C-Tech] #841255
11/04/10 08:47 AM
11/04/10 08:47 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Correct the ASD fires the pump for 3 seconds every time the key is turned on.Ive had a few also where the shutters under the pickup broke and didnt turn.You should be able to fell the relay click on when the key is turned on.As suggested check that the dist is turning as belts were a common problem with them.Ive even seen some that the teeth get torn off and they skip them catch then skip.They are easy cars to diag and work on.Also check the positive cable real close to make sure one of the wires hast broken.I also had one that a large ground on the rear of the head had broken and wouldnt start.Rocky
Chrysler Firepower
Re: 4 banger trouble-shoot .... [Re: therocks] #841256
11/04/10 03:13 PM
11/04/10 03:13 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
THX guys ferr da input ... NO news yet ... he is working on lots of regular peoples cars in prep for the winter.
Oh ... it is NOT a belt failure. It does have compression ... you can hear-it in cranking. I have lost a 2.2 belt before ....I know how THAT sounds like during cranking
Re: 4 banger trouble-shoot .... [Re: dOc …] #841257
11/04/10 03:19 PM
11/04/10 03:19 PM
C-Tech Offline
C-Tech  Offline
I still lay odds on the pick up coil.
Kevin
Re: 4 banger trouble-shoot .... [Re: C-Tech] #841258
11/04/10 03:24 PM
11/04/10 03:24 PM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
THX C .... if you look at the first post ...this is what I thought also.
It is in his hands ... but I wish it was diff. This Caravan gets TWICE the fuel econ of my diesel dually with the truck camper(this was prepped for my FL excursion)
Re: 4 banger trouble-shoot .... [Re: dOc …] #841259
11/05/10 10:28 AM
11/05/10 10:28 AM
C-Tech Offline
C-Tech  Offline
Sent you a PM Doc
Kevin
