Re: BLENDING FUEL
[Re: 493_DART]
#840060
10/29/10 02:24 AM
10/29/10 02:24 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
got them from summit , alone-- i think $60 or so for the pair? id have to look.
Eddy packaging ( felpro 8519pt) blue
the old ones were White with a thick coating.
i didnt know the new "eddy" standard port/ rb gaskets were felpro. they werent last spring!
Your right, they werent last Spring! Like I said, things have changed. Theres been a major shakeup in the mopar head gasket production to the Down side.
My tip, if you need head gaskets, and the 8519pt,s fit the bill. Get the Summit, Mopar, rebuild kit for $65 bucs. It includes the 8519pt,s and almost everything else you need for a engine rebuild.
If your going to spend 60 bucs for gaskets anyways, buy the kit and get it all.
IMO, These kits too will run out soon, once everyone realizes the true value of them. mike
Re: BLENDING FUEL
[Re: sixpackgut]
#840061
10/29/10 02:35 AM
10/29/10 02:35 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
if you can get AV gas its only about $4 a gallon here. i mix 5 gallons of AV gas to about 10 gallons of 93 when i go to the track
whats the octane on AV? is it hard on rubber lines , etc.. ?
100LL av gas is what i buy. i guess its 100 octane. i really dont know. its lighter than normal gas so jetting up a little would help(this might be problem for you )
100LL means 100 octane and low lead.. ![](/ubbthreads/images/graemlins/thumbs.gif)
Chris.. ![](/ubbthreads/images/graemlins/wave.gif)
