71 b-body w/ A/C underhood bracket question
#838952
10/25/10 08:40 PM
10/25/10 08:40 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
can some one tell me if there is suppose to be a bracket that holds the heater valve deal on the passenger side inner fender? if so, does anyone have a picture? thank you! -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: 71 b-body w/ A/C underhood bracket question
[Re: mopars_1]
#838953
10/25/10 08:49 PM
10/25/10 08:49 PM
Posts: 2,592 None
71rm23
None
Yes, there is a bracket. It goes towards the backside of the passengers fender (mine has it). Might/should be a hole there for it. Sorry, I dont have a picture right off hand.
[Re: 71rm23]
#838958
10/28/10 02:15 PM
10/28/10 02:15 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I have no reason to believe that mine has been replaced as the car only has 46,000 on it and is pretty much an untouched original car. My control does not work so it's blocked off. Vacuume moves the rod but will not close the valve. Will be working on that tonight Not to hijack but do you know where the 2 vacuume hoses go on the A/C cars that are located below the blower motor? I assume the large one goes to manifold vacuume and the other goes to the control valve. Greg
[Re: roadhazard]
#838959
10/28/10 02:29 PM
10/28/10 02:29 PM
mopars_1
Ridgeland Wi
awsome! thanks for the pictures! that's exactly what I needed.
[Re: mopars_1]
#838960
10/28/10 03:00 PM
10/28/10 03:00 PM
roadhazard
Akron, Ohio U.S.A.
That's what we are all here for!
I've received so much help on this site and always glad to recipricate when I'm able
If you need anything else just let me know
[Re: roadhazard]
#838961
10/28/10 07:30 PM
10/28/10 07:30 PM
Posts: 2,592 None
71rm23
None
Greg
Greg- Do you have a clearer pix? I know there is a vacuum can. I think the small one goes to that. The can "stores" vacuum for use. The large one goes to manifold.
[Re: 71rm23]
#838962
10/28/10 08:47 PM
10/28/10 08:47 PM
mopars_1
Ridgeland Wi
would you happen to a picture of the smaller canister? Id be missing that to..
[Re: 71rm23]
#838963
10/28/10 09:05 PM
10/28/10 09:05 PM
roadhazard
Akron, Ohio U.S.A.
Greg
Only canister is under the battery tray and didn't have anything hooked up to it (bought the car without motor). I have no idea what it's for
I'll take a pic if that's what 71rm23 is refering to
[Re: mopars_1]
#838964
10/28/10 09:07 PM
10/28/10 09:07 PM
Posts: 2,592 None
71rm23
None
Not right off hand I dont. Its mounted under the battery tray. I'll see if I can round one up.
[Re: QuickBpBp]
#838969
10/28/10 10:10 PM
10/28/10 10:10 PM
roadhazard
Akron, Ohio U.S.A.
Well I am gonna say that is NOT correct with a factory A/C on a 71 B-body...That is a set-up unlike any I have ever seen and looking at the bracket it was bent/made to fit...I will post a picture of the correct valve and bracket that came off my 71 1 owner original paint car...
Say what you want but that IS original paint in the engine compartment and the bracket appeared to be bent to get away from the BB manifolds (original 318 car) factory bolts and holes
[Re: QuickBpBp]
#838971
10/28/10 10:32 PM
10/28/10 10:32 PM
roadhazard
Akron, Ohio U.S.A.
You are CORRECT Now I have more money to spend Mine must have been replaced early on in it's life Edit; no mine must be some kind of replacement type it's not really like the later model
