Re: Brake Warning Light!
[Re: challenger70]
#838502
10/26/10 08:23 AM
10/26/10 08:23 AM
Posts: 531 Virginia
RM21N0A
Virginia
Not sure if this will be helpful, but a couple of months ago my brake warning light started staying on constantly, but not fully lit. Just sort of "half-bright". Came on bright when parking brake was on, like it should, but always stayed halfway lit when brake was off.
Brake system seemed fine, tried everything, no change, until I took the sending unit apart (pic attached), cleaned it, reinstalled, light started working properly again.
[Re: RM21N0A]
#838503
10/26/10 11:00 AM
10/26/10 11:00 AM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Thanks guys, I may have bumped the parking brake when I put the column back in If not then I will try the "swift kick method" and then rebuilding the sensor. Is it possible to get the sensor out w/ out getting fluid all over?
[Re: challenger70]
#838504
10/26/10 01:55 PM
10/26/10 01:55 PM
Posts: 7,506 Az
Crizila
Az
Once you get things back together, if you don't have a leak in the front or back brake system ( you might want to pull the drums to be sure ), put slow steady pressure on the brake pedal and the switch will center itself and the light will go out. A switch problem is not likely and to check the wire for an external ground, remove it from the switch and the light should go out ( wire grounds throuhg the switch ).
Fastest 300
[Re: challenger70]
#838505
10/27/10 09:57 AM
10/27/10 09:57 AM
Posts: 531 Virginia
RM21N0A
Virginia
Quote: --------------------------------------------------------------------------------
From what I remember, there was no leakage. Just crawled underneath, pulled off the wire, unscrewed the sensor from the dist block (not a proportioning valve). I may have stuffed a small rag in the hole, can't remember.
One of the tests I tried before taking it out was removing the wire from the sensor, then using another wire with gator clips to ground the sensor wire to the car body. Light came on halfway, with ign switch on and parking brake disengaged.
Still doesn't make sense to me, not sure what the deal was.
[Re: RM21N0A]
#838506
10/27/10 11:38 AM
10/27/10 11:38 AM
Posts: 3,903 Oregon
hooziewhatsit
The light is turned on by being grounded from either the prop valve, or the e-brake.
Unhook the wire going to the prop valve and see if it goes out. If it does, that's what's turning it on. If not, it's the e-brake. That should at least narrow it down.
